how to test a crank position sensor
Old 05-19-2006, 11:32 PM
MW2469's Avatar
MW2469
MW2469 is offline
Stage IV
Default how to test a crank position sensor
does anyone out there know of a way to test a crank position sensor to see if its sending a signal? please see my question under CUSTOM BIKES... "custom bike no start" for the reasons I need to find this out-I'm stumped-anyone out there with ign knowlage willing to take a stab at my problem?[sm=headbang.gif][sm=feedback.gif]
bizzaro (09-04-2016)
Old 05-20-2006, 11:59 PM
wlbowers's Avatar
wlbowers
wlbowers is offline
Default RE: how to test a crank position sensor
Put an oscilloscope on the sensor leads and spin the engine. You should see a pulse coming from the sensor.
Old 05-21-2006, 02:38 AM
MW2469's Avatar
MW2469
MW2469 is offline
Stage IV
Thanks for the reply.what do I do if I can't lay my hands on a o'scope? Any other options?
Old 05-21-2006, 02:49 AM
piniongear's Avatar
piniongear
piniongear is offline
I have sent you an email about getting the Position Crank Sensor procedure to you. If you respond to that I will be glad to forward it to you................piniongear
Old 05-21-2006, 04:55 PM
wlbowers's Avatar
wlbowers
wlbowers is offline
ORIGINAL: MW2469
The CKP sensor has a B+ power supply, a ground, and a signal circuit.
As the crankshaft rotates, the wheel teeth interrupt a magnetic field produced by a magnet within the sensor. The sensor's internal circuitry detects this and produces a signal which the ECM reads. The ECM uses this signal to accurately measure crankshaft velocity which is a variable used in order to detect misfire, spark and, fueling.
Looking at your service manual find the wire that goes to the B+ Measure from this wire to ground for the DC supply voltage. Measurement should be taken on the sensor side of the connector. Ground connection as well.
On my Dyna this wire is marked BK for Black. Do this test at rest and with the engine spinning. A loose connection could break as the motor shakes.
If you have voltage present with the key on and with the engine spinning move the positive meter lead to the Signal wire. This is marked R for Red on my Dyna. With the engine spinning you should see a voltage signal on that wire.
You should measure the signal at the sensor connector and the ecm to verify it is reaching the brain.
Good Luck
Old 08-17-2009, 08:43 PM
FXDWG2002's Avatar
FXDWG2002
FXDWG2002 is offline
Piniongear, I hope you still monitor this thread. Would you mind sending me that Crank Position Sensor procedure to me?
fxdwg2002 at verizon dot net
Old 08-18-2009, 07:27 AM
rbabos's Avatar
rbabos
rbabos is offline
Is there no across the terminal resistance check that will varify it's condition, like ignition coils?
Ron
Old 08-18-2009, 05:42 PM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
And the crank has a skipped tooth so the ECM knows where TDC is.
Most of these sensors work by majec, sometime the spell wares off.
Old 08-18-2009, 07:15 PM
FXDWG2002's Avatar
FXDWG2002
For those of you that don't know, 0v-5v is TTL logic used in 100% of digital circuitry. This is digital because the red wire and black wire are independent of any power source or ground on the bike.
Ok, I do not have an o'scope to test this with. But it is my understanding that the magnet in the CKP sensor will produce a 5v pulse every time the missing teeth come around. This can be seen on a multimeter as a change from zero (actually 2.81v) to 5v. Do I understand correctly?
It takes 2.81v just for the ECM to register the presence of the CKP sensor.
I kept the plug hooked up between the CKP and the ECM. I pushed straight pins into the connector so I could see the operation (or lack there of) in circuit.
Old 08-18-2009, 07:54 PM
rbabos's Avatar
rbabos
rbabos is offline
Sounds good to me.
Ron
Quick Reply: how to test a crank position sensor
