how to test a crank position sensor
Old 11-24-2009, 10:05 PM
LiquidMagnum's Avatar
LiquidMagnum
LiquidMagnum is offline
Stage II
Piniongear, I hope you still monitor this thread. Would you mind sending me that Crank Position Sensor procedure to me?
Old 11-28-2009, 09:50 PM
geargrinder's Avatar
geargrinder
geargrinder is offline
If your tach reads approx 300 RPM while cranking, your crank sensor is working. To test for a crank signal with a multimeter, switch meter to 'AC Volts'. measure from sensor ground to signal wires, should read at least 5V AC while cranking.
The following 2 users liked this post by geargrinder:
F107 (02-03-2020), Yankee Dog (01-27-2020)
Old 11-28-2009, 11:25 PM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,684 Likes on 850 Posts
You can use a ohm meter to check resistance with the sensor unplugged, it is a coiled magnet and b+ to sensor ground has specs to produce a correct signal, b+ to sensor base is a short to ground test. It would be how helpful a dealership would be to give the specs for the resistance test.
The paperclip tests give voltage output numbers but still need to know the out of range specs of that test.
Old 12-19-2009, 11:10 AM
jmetro's Avatar
jmetro
jmetro is offline
TONS OF BAD INFO ON THIS THREAD! NONE OF WHAT WAS MENTIONED SO FAR IS CORRECT.
1. there is no batt voltage to the CKP, period
2. the pulse is not a pulse but a constant a/c voltage PRODUCED by the ckp sensor itself
3. the drop in a/c voltage caused by the missing tooth tells the ecm what part of the stoke the engine is on, and the slow down of the crank (upon compression), and lower a/c voltage tells the ecm what phase the engine is on.
4. the only way to test the ckp, is to UNPLUG it from the ecm, put a multimeter on the 2 wires, (R/B and B) and crank the engine. it should show 1-5 VA/C.
5. this is hit or miss, some ckp show good when they are not, but if it shows bad, it is.
The following 5 users liked this post by jmetro:
Angel Espinoza (06-02-2020), Fritz Franz (12-11-2021), MSgt1371 (02-11-2018), tizz440 (03-12-2018), wildbill01 (07-19-2021)
Old 12-19-2009, 01:25 PM
producer's Avatar
producer
producer is offline
Smile
JMETRO,
thanks for the information.
Old 12-19-2009, 01:54 PM
rbabos's Avatar
rbabos
rbabos is offline
Restistance is X 100 scale, should read 10. That's what my 07 softail is, if that helps. 5 volt ac pulse when cranking.
Ron
Old 12-19-2009, 04:20 PM
car5car's Avatar
car5car
car5car is offline
Crank sensor is kind of alternator. Crank sensor has 1 coil, Harley alternator has 2 coils, rest of bikes 3 coils.
Old 05-08-2010, 12:24 PM
jspence's Avatar
jspence
jspence is offline
Stage I
I would just like to thank FXDWG 2002 for your input on how to test a crankshaft position sensor. It worked for me and saved me money when needed. My bikes up and running at a minamal cost. Thank You, and this forum for everything. Really Appreciated... Popjoe!!!!!!
Old 03-01-2012, 10:25 AM
Muhran's Avatar
Muhran
Muhran is offline
Stage I
Default don't need a scope
Originally Posted by MW2469
Thanks for the reply.what do I do if I can't lay my hands on a o'scope? Any other options?
Go to Radio shack, buy a 5 volt LED for $2.00, time response is fast so you can see the pulsing, works great - a lot chaeper than an oscilloscope..Mike
Old 03-08-2014, 07:07 PM
barrister86's Avatar
barrister86
barrister86 is offline
This is brilliant. If you happen to have a camshaft position sensor (My 2000 FLHR-EFI does) this method works for it too. It can be difficult to hold a multi-meter and try to read a voltage. Get the 5 volt led and solder a short length of wire (pigtail) onto each terminal, then a small alligator clip on each of the other 2 ends. Unplug the ckp harness, connect the alligator clips and viola'. I also use this method to ck injector harnesses.
Quick Reply: how to test a crank position sensor
