Sponsored by: Jekill and Hyde
engine upgrade? 1450-1550 big bore
Old 06-28-2009, 06:41 PM
athasl's Avatar
athasl
athasl is offline
Default engine upgrade? 1450-1550 big bore
I have a 2004 heritage.I have bassani 2 into1 pipes,power comander,screaming eagle air intake.I was thinkng of going from 1415cc, adding the 1550cc Big Bore Kit, with the cams. WHAT WILL THIS DO? IS IT A GOOD IDEA? "I need some input,please".
Old 06-28-2009, 07:33 PM
schmeg's Avatar
schmeg
schmeg is offline
Its certainly not a bad idea. What do you want to achieve, and how wide is your wallet?
Old 06-28-2009, 07:42 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
A rock-solid combo is a Wood 6, bore to 98", Good* set of heads.
Your power will JUMP, dramatically, and may very well be smoother also.
Good exhaust and tune. Great combination.
Scott
__________________
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Maxton Mile World Record
4500 sq ft. facility
See us on Facebook.
Old 06-28-2009, 07:58 PM
schmeg's Avatar
schmeg
schmeg is offline
Good advice from Scott. If money is an issue, you can start with the cams, using a +4 degree cam gear, and do the cams for now, and do the rest of the motor later. It would be simpler and cheaper to do it all at once though.
Old 06-28-2009, 09:18 PM
KumaRide's Avatar
KumaRide
KumaRide is offline
Surprising no one asked you some basic questions first. Think about how you ride and what you want out of the cam in terms of tq - more low end, low to mid, mid to high... Do you ride 1up or 2up? How many miles are on your bike? Have you ever changed or checked the cam tensioners - you made need to consider that as well or gear drive or the newer HD hydraulic tensioner cam plate setup... Are you doing the work yourself? How much do you want to spend? Do you want lots of tq or a nice boost. The "right" cam alone will wake a 88" bike up nicely. And several cams will work great in a 88" and 95" motors. Also, be sure not to over cam or get mislead by high tq or hp numbers.
Not sayin to do this build. It just raises some good points and provide some info for you as you seem new to this cam stuff
http://www.americanrider.com/output.cfm?id=1054045
Old 06-30-2009, 12:30 AM
bigoscycles's Avatar
bigoscycles
bigoscycles is offline
If I were doing this I would recommend boring your 88 cylinders to a set of 95 pistons. I would run around 10.5.1 CR. I would suggest wood's TW6, 400, or 408 gear drive cams. I would also recommend changing the gearing in the primary. Get a good tuner and you should be good for 1 up, 2 up, or maybe even 3 up. Keep the wallet open because it's not going to be cheap. Just my 2cents.
Old 06-30-2009, 04:05 PM
Firetender's Avatar
Firetender
Firetender is offline
I think you'll get a nice power boost and can live with it. Understand however that without headwork and a high-lift cam you will be, in a way, 1/2 done. But don't let that hold you back!
Old 06-30-2009, 05:55 PM
Hillsidecycle.com
Sponsor
The reason I made the reccomendation that I had, was the fact that it is a combination that brings it on so soon, and has the ability to stay on as far as it does, makes it a such a versatile one, that from Dyna owners to the Bagger crowd, no one is left out in the cold.
Scott
Old 06-30-2009, 06:42 PM
Dalton's Avatar
Dalton
Dalton is offline
Not necessarily true. There are cams out there, HQ0034 for example that will really wake up an otherwise stock bike.
I do agree that to get themost, headwork is where it is at, but a high lift cam is not a true necessity unless you are trying to wring the last hp outta the combination. There are many low to mediun lift cams out there that really do well - HQ 575 & 0034, Woods 6, Andrews 26, Zippers 575 and on and on. It is not neccessary to go beyond .600 lift IMO.
Old 06-30-2009, 07:17 PM
1953riderforlife's Avatar
1953riderforlife
1953riderforlife is offline
I've had the same sort of question. I ride stock 88 '05 Road Glide with power commander, screaming eagle air intake and V&H oval slip ons. I do a lot of 2 up riding, highway and mountain twisties. Have tour pack and usually carry a heavy load of luggage. I haven't noticed a lack of power but worry that I'm putting too much strain on the engine.
Quick Reply: engine upgrade? 1450-1550 big bore
