correct Locking of detachable windshield on a Road King
Old 05-18-2006, 01:39 PM
jeffjohnson1's Avatar
jeffjohnson1
jeffjohnson1 is offline
Stage IV
Default correct Locking of detachable windshield on a Road King
Hi, I am new to the forum and a new Road King owner (2004 RK standard - injected). I have read the manual and am not seeing the detail that I need on the locking in of the windshield. I can see how (I think) it is supposed to lock in, but the two spring clips are not low enough to drop behind the top rubber bushing. I assume that these are supposed to drop down behind the bushing, keeping the windshield from rocking forward and becoming disengaged. Is this correct? If so, it looks as though these clips need to be bent down so that they normally rest in a lower position. I do not want to start benting on these spring clips until I have some knowledgable input. Thanks,
Jeff
Old 05-18-2006, 01:47 PM
Manish_Hawg's Avatar
Manish_Hawg
Manish_Hawg is offline
Default RE: correct Locking of detachable windshield on a Road King
My clips were too high too. Per the dealership's instructions I bend them down by hand and I haven't had any problems with them breaking or anything. They eventually will become too high again and I just keep bending them down. I remove/install my windshield almost daily depending on my destination.
Old 05-18-2006, 02:31 PM
RBJones's Avatar
RBJones
RBJones is offline
One of my springs was too high and kept popping up. I just took it off and rebent to match the one that worked by putting it in a vise and using pliers. Pretty low-tech. Now no problem.
Old 05-18-2006, 02:32 PM
venture33's Avatar
venture33
venture33 is offline
This topic was covered in detail within the last month, including a pic of how the clips should be bent.
Search for it. If I find it before you, I'll post a link.
BTW...get them bent right or the windshield can blow off (forward).
Old 05-18-2006, 03:05 PM
venture33's Avatar
venture33
Here ya go...
Discussion
Fix
Good luck
Old 05-18-2006, 03:40 PM
jeffjohnson1
Stage IV
Thanks gentlemen, these are some really great ideas - I'll get right on it when I get home. Special thanks to Venture33 for the pics - they make it a lot easier to be able to see what it is actually supposed to look like.
Jeff
Old 05-18-2006, 04:05 PM
Big Ted's Avatar
Big Ted
Big Ted is offline
ORIGINAL: jeffjohnson1
Jeff
I agree, great post! Mine where way off and I didn't even know it. Thanks again.
Old 05-18-2006, 04:07 PM
aquaskiman's Avatar
aquaskiman
aquaskiman is offline
Here is a pic of how I bent the clips, bend them like this and the windshield won't come off again.
[IMG]local://upfiles/9350/D3186A6C8105491395B056939DCA63FA.jpg[/IMG]
Old 05-21-2006, 11:05 PM
Longtimegone's Avatar
Longtimegone
Longtimegone is offline
Makes you wonder how they were supposed to stay on in the first place. Or wonder how the windshield stayed on.
Montana Cowboy
04-09-2013 11:10 AM
dwinterringer
01-27-2012 10:41 AM
loner1
12-03-2010 09:16 AM
wdcamp
03-09-2008 10:34 AM
Mr. Clean
10-13-2007 06:31 AM
Quick Reply: correct Locking of detachable windshield on a Road King
