Will Fatboy pipes fit a Softail Standard??
Old 06-06-2009, 08:33 PM
Firebug's Avatar
Firebug
Firebug is offline
Default Will Fatboy pipes fit a Softail Standard??
Hello,
New here from Wisconsin.
I have a Ultima Softail frame that is a 1999 Softail standard replica. I was going to mount a set of 2003 Fatboy pipes to try and get through inspection.
The softail standard bracket will not work but does anyone know if I get a Fatboy exhaust bracket will it bolt up to the frame and work to mount these pipes?
Thanks
Old 06-07-2009, 08:02 AM
08fattoy's Avatar
08fattoy
08fattoy is offline
I put 2008 softail standand pipes on my 2008 fatboy. You will probably need a mounting bracket. I had to remove mine to mount the pipes.
Old 06-07-2009, 08:33 AM
mmont's Avatar
mmont
mmont is offline
Down here in Texas they will fit not sure way up there
Old 06-07-2009, 09:27 AM
BigSeaDaddy's Avatar
BigSeaDaddy
BigSeaDaddy is offline
Being from Texas myself I have no idea what this is supposed to mean.....
Look I know this my sound like red neck engineering but if you are only trying to get through an inspection do not worry about it. Get it mounted up on on the jugs then hold them secure with several loops bailing wire.
I am sure you are only going up the road. Get it done and then get your real pipes back on your bike.
If all them damn rat bikes with all that crap they got on them can pass then bailing wire should not be an issue.
Just my 2 cents unless its a fashion thing up to the inspection place...
Old 06-07-2009, 09:50 AM
Firebug's Avatar
Firebug
Firebug is offline
I was thinking the same thing.
I saw a few fatboy exhaust brackets used online for $20-$30 so I was wondering about just ordering one of those if it would fit or just making a rough mount with some flat steel.
82flh
01-18-2016 05:04 PM
Slamed Slim
05-07-2015 05:25 PM
asheborogn
05-13-2010 09:16 PM
cowboy Harry
09-16-2007 10:09 AM
GlassBikerNC
06-25-2007 10:57 PM
Quick Reply: Will Fatboy pipes fit a Softail Standard??
