What size are sportster axles?
Old 05-29-2009, 10:20 AM
07bobber's Avatar
07bobber
07bobber is offline
Default What size are sportster axles?
Are the newer sportsters 1 ", 3/4" or 25mm?
Are there any with 1 inch axles? What years?
Old 05-29-2009, 03:03 PM
cHarley's Avatar
cHarley
cHarley is offline
Yes, all of the above. Which year are you referring to?
Old 05-29-2009, 03:54 PM
07bobber's Avatar
07bobber
07bobber is offline
I need to find a wheel bearing for a sportster 21" wheel with a 1" id so that i can make it fit to my dyna...all i wanna know is if there is a newer sporty with 1" front axle.
Old 05-29-2009, 04:04 PM
cHarley's Avatar
cHarley
cHarley is offline
04 Sporties had 3/4 front axles, 05 & 06 had 1" front axles, and in 07 they went to 25mm front axles.
The following 2 users liked this post by cHarley:
BlueridgeXL (03-20-2024), hammer6315 (03-20-2024)
Old 05-29-2009, 05:24 PM
07bobber's Avatar
07bobber
07bobber is offline
Thank you sir you are a scholar and a gentlemen.
The following 2 users liked this post by 07bobber:
Old 06-17-2009, 04:24 PM
07bobber's Avatar
07bobber
07bobber is offline
anyone know a p/n for a wheel sleeve to a front sporty wheel with the 1 inch axles
Old 08-19-2011, 11:34 PM
trainman123's Avatar
trainman123
trainman123 is offline
I have an 883.1200 with a 3/4" front and a 1" rear axles. I changed bearings and reinstalled them into a set of wire wheels. Bought a cheep hot plate from Walmart and heated the hub and tapped on opposite with a soft mallet. Bearings just fell out. Cooled bearings in the freezer and heated the new hub. The bearings slid back into the new wheels.
Fronts axles are:
'04 - '07: ¾"
'08+: 25mm
Rears axles are:
'04: ¾"
'05-'07: 1"
'08+: 25mm
Old 08-22-2011, 09:12 AM
aoehero's Avatar
aoehero
aoehero is offline
Hey all mind if I join the conversation? I could use some help with my project. Im trying to use wire wheels of both front and rear with a 1" axle on a 3/4 dyna axle frame. I am assuming you just cant slide a 1" alxe in place of both front and rear. Do they make a bearing kit to reduce the 1" to 3/4? or do I need to replace the swing arm and forks?
thanks in advance.
Old 08-22-2011, 09:29 AM
aoehero's Avatar
aoehero
aoehero is offline
does anyone have any experience with the axle reducers?
Old 09-22-2011, 10:05 AM
kenlani's Avatar
kenlani
kenlani is offline
Default Me too
I too wanna know if the reducers work- also do the bearing inner spacers simply float in the hub? will they interfere with the reducers? I need to put a 1" axle front wheel on my 05fxdwg 3/4 axle
Noel Briffa (09-08-2022)
Quick Reply: What size are sportster axles?
