Ham can air cleaner replacement
Old 05-11-2006, 09:36 PM
jeeper53's Avatar
jeeper53
jeeper53 is offline
Default Ham can air cleaner replacement
Anyone replace the stock air cleaner with another type and if so can you post pics and if you don't mind sharing total costs to do so. Is the job easy enough to do and is there a lot of added stuff like breather tubes etc to add? I personally like the round aftermarket styles but please add your photos and recommendations. Thanks.
Old 05-12-2006, 05:43 AM
D1LD's Avatar
D1LD
D1LD is offline
Default RE: Ham can air cleaner replacement
I put on a Arlen Ness Big Sucka. I dont have a full filter cover on yet , Just a filter cap I made at work out of aluminum It leaves the filter exposed and It works great but you cam hear the air going in while crusing and when you crack the throtle its noisier than i would like it to be.
https://www.hdforums.com/photo.asp?p...Type=6&apage=1
D1LD
Old 05-12-2006, 11:02 PM
Blackbird's Avatar
Blackbird
Blackbird is offline
I replaced the stock filter with an Arlen Ness Big Sucker Stage I Kit that comes with a round K&N air filter. I then added a used oval cover with a new "Live To Ride" insert. Total cost around $175.00 (Highly Recommend).
Old 05-14-2006, 11:07 AM
Mal74's Avatar
Mal74
Mal74 is offline
I bought an aftermarket tear drop air cleaner. It came with a foam filter, so I bought a K&N filter for it. I did this for the look, and because the original system was puking oil.
I added the breather tube system and ran the tube under the bike. Total cost for everything was about $200.00.
Of course, most Harley riders recognize it's a Sportster. Every now and then, someone asks, thinking it's a Low Rider.
iHodor
2018+ Softail Models
07-24-2019 07:29 AM
Tangle Eye
06-06-2018 04:48 PM
Wagney
04-13-2016 09:33 PM
tim_espana
12-12-2014 10:46 PM
patsac
07-19-2009 02:21 PM
Quick Reply: Ham can air cleaner replacement
