95 cu.in. verses 96 cu.in
Old 05-16-2009, 10:21 PM
mountian man's Avatar
mountian man
mountian man is offline
Question 95 cu.in. verses 96 cu.in
I'm not big on knowledge of cubic inches on engines and kinda confused on the defference in 95 and 96 I here some people talking about.
Please I know its 1 cubic inch difference,Whats the purpose in them being so close and so on.Someone want to help me out here.Thanks
Old 05-16-2009, 10:30 PM
Intrepid175's Avatar
Intrepid175
Intrepid175 is offline
The 95 is an older stock 88 ci engine that's been bored out to 95 ci. They replace the cylinders and pistons to effect the change.
The 96 is Harleys upgrade of the older 88 ci engine. They changed the stroke in this case in increase the engine displacement. The 88 and 96 engines both have the same pistons size, it's just the stroke that makes the difference. You can also apply the cylinder and piston swap that was used to take the 88 to 95 ci on the stock 96 engine to increase it's displacement to 103 ci.
Old 05-16-2009, 10:32 PM
dawg's Avatar
dawg
dawg is offline
Received 2,950 Likes on 1,709 Posts
95 is 1550, 96 is 1584 It's in the stroke
Old 05-16-2009, 10:39 PM
mountian man
That helps,Are the heads on 88 and 96 the same?
Old 05-16-2009, 11:58 PM
emwolb's Avatar
emwolb
emwolb is offline
mountain man, the original size of the two were 88 cu in. and 96cu in. the 88 cu in was 3-3/4" bore with 4" stroke. in 07 i believe for the touring and 06 for the dyna harleys they went to a longer stroke of 4-3/8" stroking the basic same engine by 3/8" more stroke, known as a stroked motor. so there ya go, the 88 when bored to 3-7/8" is a 95 inch motor. the newer stroked version stock is 96". and when the 96" stock motor is bored from 3-3/4" to 3-7/8" it becomes a 103". hope this helped to simplify it for you.
Old 05-17-2009, 02:45 AM
teqsand's Avatar
teqsand
teqsand is offline
Big Kahuna HDF Member
Good question....
Old 05-17-2009, 02:57 AM
kingkingking's Avatar
kingkingking
kingkingking is offline
logic says the 95 will rev higher than the 96 and make its power higher in the rev range, whereas the 96 would make more torque lower in the rev range and not rev as high. Of course there arent many 95s with the stock cam or heads so the waters are muddied further...
Old 05-17-2009, 06:01 AM
dog155's Avatar
dog155
dog155 is offline
The difference is always what makes it all work.Comparing apples to apples there should be almost no difference in the 2 motors.Again you can also build two motors identically and they will still be a little different.It's the nature of the beast.
Old 05-17-2009, 07:43 AM
MassHD's Avatar
MassHD
MassHD is offline
What do I have to do to my 96 to beat my friends 95 in a straight line test?
Old 05-17-2009, 07:46 AM
blkfalc4's Avatar
blkfalc4
blkfalc4 is offline
Cams, compression, and headwork will work.
Quick Reply: 95 cu.in. verses 96 cu.in
