Power Commander V on 2007-2008 Sportsters
Old 05-04-2009, 01:57 PM
watdog's Avatar
watdog
watdog is offline
Default Power Commander V on 2007-2008 Sportsters
Is there any reason why I couldn't install this on my 2008 Nightster and use the PC-V maps off the Power Commander website? Is there any difference between the 2008's and the 2009's?
Thanks ahead of time.
Old 05-04-2009, 03:42 PM
Hal64hd's Avatar
Hal64hd
Hal64hd is offline
It depends on the base map in the ecm, If the maps in the ecm are the same for 08-09 then there is no problem. But its best to have it checked on a dyno. There is also the option of adding the autotune module.
Old 05-04-2009, 08:33 PM
harley6six's Avatar
harley6six
harley6six is offline
watdog,
you shouldn't have any issues, I am running the PC 5 on my 08 nighster and it is doing just fine. But I will make this disclaimer, I did get mine from Fuelmoto and it came preconfigured with a map for my setup. The main fact is, that I am running it and very happy with it.
Old 05-04-2009, 09:51 PM
stng_96's Avatar
stng_96
stng_96 is offline
Man, after what soup(another nightster owner here) has been going through with his bike medusa, which i believe had a PC V, I would be leary about them things unless I was absolutely sure it was for my bike and my setup.
Old 05-04-2009, 11:00 PM
watdog's Avatar
watdog
watdog is offline
Thanks for the responses. The main reason I am concerned is I am not done modding my bike, and I want the freedom of not having to go to fuel moto everytime I change something on my bike. It's probably not as big a deal as I am making it out to be.
Old 05-05-2009, 06:50 AM
soup's Avatar
soup
soup is offline
It could be the tech was an idiot, or it could be a bad PC5, but I'm spooked on them. They are doing a complete rebuild on my engine because of a meltdown, I told them to drop kick the PC5, I'm gonna contact the manufacturer and ship it back to them, see if it is defective, I will probably go to the SERT in the future. For right now I'm gonna be happy just getting her back before the summer hits.
Old 12-30-2009, 03:09 PM
Turtle28's Avatar
Turtle28
Turtle28 is offline
Stage IV
Default PCV in 2007 Sportster?
Guys, I really need some help....
Here in Brazil our gas with 25% of ethanol on it chemical composition, so to find the best setup we usually pick up a map and modify to attend our gas.Is impossible find a map to match with our accessories and gas....
Is it possible use PCV in a 2007 EFI Sportster?? Probally only the base maps on ECM are different between models, right?
Thanks a lot
Old 12-30-2009, 03:30 PM
brkbstrd's Avatar
brkbstrd
brkbstrd is offline
I'm running a PCV on my 07 1200. Works fine. Ran great with the fuel moto map, ran great with a map from dynojet, runs better with autotune.
Old 12-30-2009, 04:14 PM
soup's Avatar
soup
soup is offline
The PC V was not the issue whith Medusa. After 5 breakdowns and sitting in the shop ALL Summer, they finally figured out the issues with my bike. ( At least I hope they have ) near as can be told, and this is just an opinion, my problem stemmed from a factory defect. In the end they had to completely re-build the top and bottom on the bike, replacing everything from the flywheel and cam shaft ( Both heavily damaged ) to the pushrods, valves, cams, pistons, new oil pump, all new lines, etc etc etc. Basically if it was in the engine and moved....they replaced it.The bike was laid up for 6 months because of legal issues ( which are still ongoing) and is finally home. Unfortunately the weather has not gotten above 29 degrees, and we had 2 feet of snow so I have not had a real oppurtunity to run her. I sold the PC V to Midnight nad he does not have any issues running it on his set-up.
Old 12-30-2009, 04:24 PM
Turtle28's Avatar
Turtle28
Turtle28 is offline
Stage IV
Thanks men...
I really don't understand the reason why on PC site they only recommends the PCIII to my model year bike....
I used to use COBRA FI2000R, but I thinking to upgrade to 1250cc and probally PCV is the best choice to my bike, or not?
thanks
Quick Reply: Power Commander V on 2007-2008 Sportsters
