Cluctch adjustment on Sportster 2007
Old 05-01-2009, 08:48 PM
Broue's Avatar
Broue
Broue is offline
Default Cluctch adjustment on Sportster 2007
Hi
I just come to buy a MRC clutch lever. This is suppose to reduce by 50% the lever effort,
That what they said. So I whant to know if somebody already install this on Sportster.
My dealer said to me it's very easy to install. I just have to put the new part in place and do the clutch adjustment. Can anybody give me some clue about how to adjust the clucth and the step to follow.
Bernard
Old 05-02-2009, 01:12 AM
XLCR4GM's Avatar
XLCR4GM
XLCR4GM is offline
Installation Instructions
This site is for information only and Phaedrus Cycle LLC will not be liable for any damage of any kind arising from incorrect installation or adjustment. You agree that your use of this site and any information herein is at your sole risk.
  • Installation Instructions Important:
  • MRC Clutch must be installed by qualified Harley technicians only. Precise clutch adjustment is very important in the proper operation of the MRC Clutch. Take your time: Several adjustments may be necessary before you get it just right. Clutch cable free play must be run slightly tighter than stock. The MRC Clutch may not work effectively on bikes with aftermarket clutches, cables. Levers or grips.
  • HD-0002
  • Installation Instructions: ‘94 later Sportsters & Buells Qualified Harley Technicians only
  • 1) Loosen clutch cable adjuster so cable is slack.
  • 2) Remove derby cover .
  • 3) Per Service Manual Instructions, remove stock ball & ramp assembly
  • 4) Remove retaining ring from stock ball & ramp assembly & install on MRC Clutch assembly.
  • 5) Install MRC Clutch (Be sure to use ***** included in kit as they are larger in diameter).
  • 6) Adjust clutch - Back off adjusting nut ¼ turn.
  • 7) Lube & readjust clutch cable
  • 8) Test ride
The above information is from the MRC web site. Good Luck with your installation. I installed one in my '99 XL883 and it does help out some. It is a noticeable improvement/reduction in the clutch lever pull.
Old 05-02-2009, 05:04 AM
cHarley's Avatar
cHarley
cHarley is offline
If you really want to wrench on your bike for work like this, step one is to order the HD Service Manual.
Old 05-02-2009, 06:49 AM
Broue's Avatar
Broue
Broue is offline
I already have the install instruction with the kit.
But I don't have the service manuel to see the specification for the cluctch adjustment.
Just whant know if somebody have already does it, and share his experience,
Old 05-02-2009, 07:31 AM
hollywood1959's Avatar
hollywood1959
hollywood1959 is offline
Check out this website (harley-performance.com.) It may answer some of your questions. Best of luck..............HOLLYWOOD
Old 05-02-2009, 09:13 AM
Broue's Avatar
Broue
Broue is offline
I found that clip on Youtube it's not exactly the same parts but it give you a good idea to perform the installation
( http://www.youtube.com/watch?v=HG90X...om=PL&index=73)
Also on this forum I found this
https://www.hdforums.com/forum/trans...-easy-way.html
Just come to do it and it's work, so easy
Now going for ride and see the difference
higbee76
07-23-2017 02:55 PM
overthehill?
10-04-2013 09:18 AM
mrfikser
09-22-2011 07:39 PM
Port Dawg
07-20-2011 03:36 PM
Anthony8858
09-11-2009 09:05 AM
Quick Reply: Cluctch adjustment on Sportster 2007
