Help Need jet size "72 xl 1000 Super E
Old 05-01-2009, 03:50 PM
speed8988's Avatar
speed8988
speed8988 is offline
Default Help Need jet size "72 xl 1000 Super E
I'm having issue with my 72 1000. I have a super E with a .025 and a .064 main. It hesitates before a 1/4 thottle then after 1/4 thottle it opens up. Any suggestions what jets to use or start out with.
Any help is greatly apprecated
Speed8988
Old 05-01-2009, 06:56 PM
IronMick's Avatar
IronMick
IronMick is online now
Speed8988
If you go to the S&S website here: http://www.sscycle.com/ you will find an instruction sheet for your carb.
Old 05-01-2009, 07:27 PM
SportsterBob's Avatar
SportsterBob
SportsterBob is offline
.025 seems a bit lean for an Intermediate jet....Go with a .0295 or a .031. Don't use the Accelerator pump adjuster to compensate for it either! S&S recommends shutting off the accelerator pump when jetting!
Old 05-01-2009, 08:22 PM
irondude's Avatar
irondude
irondude is offline
That main sounds small too. I use .028 and .064 main and I'm at 5000 ft!
Old 05-02-2009, 01:01 PM
speed8988's Avatar
speed8988
I'm in florida so I'll try a .031 and .068
Old 05-04-2009, 10:21 AM
d_slat's Avatar
d_slat
d_slat is offline
if you look at the spec sheet on s&s website, they recommend a range of .028 to .0295 intermediate and .062 to .068 on the main jet for a stock engine of your size. The .031 you mentioned may be a little rich, especially since you always have warm weather. I've got a 90" stroked shovelhead, which I sometimes ride when it's 30 degrees out, and i'm only running a .0295 intermediate jet. If I were you, i would avoid going too rich, especially in the intermediate jet, as it will destroy your fuel economy.
brad75raiders
EVO
09-08-2018 11:46 AM
brad75raiders
09-07-2018 04:23 PM
C_hunter77
Ironhead
09-14-2007 12:49 AM
Buckndol
Exhaust System Topics
06-19-2006 01:04 PM
stangnut
03-28-2005 10:40 PM
Quick Reply: Help Need jet size "72 xl 1000 Super E
