LED strips for front turn signals???
Old 04-14-2009, 07:17 PM
recon_sct's Avatar
recon_sct
recon_sct is offline
Default LED strips for front turn signals???
Ok guys, I recently replaced my handlebars and decided I want to ditch the stock front turn signals. However I found a small strip with 3 led's that I want to install in place of the turn signals. The led's are a two wire hook up (1-power, 1-ground) is it possible to hook these up to the stock wiring? Has anyone done something similar?
Thanks all
Old 04-14-2009, 11:43 PM
fixxr's Avatar
fixxr
fixxr is offline
You can do it , but depending on the year of your bike if it is a newer one with a comp you will be getting some code comming up .
Old 04-14-2009, 11:47 PM
crooky's Avatar
crooky
crooky is offline
My local shop is installing front, back led strip blinkers and brake light can be done on the new HD’S just need a load equalizer.
Old 04-15-2009, 12:08 AM
JaronB's Avatar
JaronB
JaronB is offline
JRK has it done to his. I think he has 5 led light strips on the trees
Old 04-15-2009, 01:43 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
yes... ditch the purple wire... that is your running light... you will loose a front running light but you will have turn sigs... if you really want a running light put a resister on the purple line to dull it down, then bridge that with the power for the turn (can not recall what color off hand) ground goes to ground... i said screw the running lights i hate that look at night... i have fogs on the front so they can see me just fine!
if you have any questions or want to see any pics just let em know...
jambo1989
01-17-2017 08:33 PM
rpmpit
EVO
24
03-30-2015 05:27 PM
RicMF
11-16-2014 06:58 AM
topdwg
04-18-2013 08:51 PM
NEBiker51
08-01-2010 08:05 AM
Quick Reply: LED strips for front turn signals???
