? on adjusting handlebars on a 06 Street Glide
Old 04-12-2009, 05:46 PM
FFeric's Avatar
FFeric
FFeric is offline
Default ? on adjusting handlebars on a 06 Street Glide
Over winter I had some KW Ergo back bars put on my bike. I had them adjust the bars one time I was there. I would like to try to adjust them again myself. Where I have them the levers have to be angled upward. If I raise the bars a bit I will be able to bring the levers down. I took the fairing cap off according to the service manual. Then it said to loosen the two front screws to the bar clamps. The radio and everything else is in the way. Is there a better way to do this? Will I need to take the radio out?
I know someone will jump in and say to use the search as aways. Well, I had no luck.
thanks
Eric
Old 04-12-2009, 06:27 PM
stro1965's Avatar
stro1965
stro1965 is offline
You can probably access the screws (the front ones at least) if you remove the ignition and pull the switch cap cover off. Otherwise, yes, pull the radio. It's easy to do IF you have a ball end allen wrench.
Old 04-12-2009, 06:31 PM
Oldman Harley's Avatar
Oldman Harley
Oldman Harley is offline
Pulling the radio is the easiet way to get to the bars and yes you must do that through the outer fairing.
Tim
Old 04-12-2009, 06:35 PM
SG 1's Avatar
SG 1
SG 1 is offline
I can reach mine by pulling the ignition and the switch cap. I have to use a regular old L shaped allen wrench and a boxed end wrench over the end of it for leverage. It's tight, but it can be done. By the way, you can only reach the two bottom bolts, but that's enough.
Old 04-12-2009, 06:48 PM
FFeric's Avatar
FFeric
FFeric is offline
When you pull the iginition off do you need a special tool to do that?
Old 04-12-2009, 07:04 PM
SG 1's Avatar
SG 1
SG 1 is offline
Just your key and a wrench. The manual tells you to turn the switch to the lock position, insert key and turn counter clockwise while holding the button under the switch. I never let mine go to the lock cause you can't turn the bars to do what ever work you've got to do. Plenty of info on the subject here, do a search, you'll find much more detailed instructions than I can give.
Old 04-12-2009, 07:17 PM
doshi's Avatar
doshi
doshi is offline
The ball end allen wrench socket seems to work the best after removing the ignition and fairing cap. No special tools needed for the ignition removal and installation, just a little patience lining up everything.
Old 04-12-2009, 07:24 PM
SG 1's Avatar
SG 1
SG 1 is offline
I can see where that might work good. Gotta get me a set of those. They were on my Christmas list but Santa must have forgot them.
Old 04-12-2009, 08:24 PM
FFeric's Avatar
FFeric
FFeric is offline
Thanks for the help guys. I got the fairing cap off and I was able to adjust my bars. The only bad part is my bars are right in the middle of my mirrors. And I just got new Performance Machine mirrors.
Old 06-13-2015, 06:13 PM
ebigfish's Avatar
ebigfish
ebigfish is offline
Default I Did it!
Gotta love hdforums...
you can find out how to do anything.
Got my handlebars in the perfect place now (rolled them back a bit...)
this helped too...
(Starting at 3:15 into it)
PS... I never did watch the whole thing, just a bit of it showed what I needed to know
Uncle Paul
07-23-2013 07:47 PM
jamie_s_72
03-06-2013 01:13 PM
jmn1960
11-07-2012 03:57 PM
JWhip
04-02-2010 09:26 PM
Irish Metal
05-21-2009 12:36 AM
Quick Reply: ? on adjusting handlebars on a 06 Street Glide
