Ride Time Tech LED tail light
Old 04-06-2009, 09:15 PM
The Old Man's Avatar
The Old Man
The Old Man is offline
Thumbs up Ride Time Tech LED tail light
Hi all,
Well in an effort to light up the back of my bike like a christmas tree I opted for LED tailight from RIDETIME Tech. http://www.ridetimetechnology.com/tail_sr.htm
It has turned out to be just what I wanted and has 100 led's and with shipping it was $99.00.
I did learn something interesting that I figured to pass along. When I bought the bike I had the dealer install the AUX running light,brake light and turn signal module. Its part number is 69461-06A. I ordered it cause a friend of mine has what I thought was the same thing on his 03 Road King. His unit makes his turn signal come on light brake lights and still are used as turn signal. Pretty slick I thought. Well when I bought the above module from Harley I found out that there was a change in the model and now it is running lights/turn signal only. Not bad as it comes with the red lens etc... Well when I installed the led brake lights now the turn signals come on as brake lights as I originaly wanted also. Don't know how it does it but I am happy as a clam. I called Keith at Ride time and he never heard of it acting that way. He said hes going to check it out. Any way Keith seems like a stand up guy and really knows his product. The LED's are brighter, about 3 or 4 times brighter.
AND they were 35 or 40 dollars cheaper then Harleys.
Old 04-07-2009, 07:19 AM
hojones's Avatar
hojones
hojones is offline
My guess is you had a loose connection some place preventing the module from making the turn signals operate as brake lights. Sometimes where you plug the module in a pin will back out in the plug.
Old 04-07-2009, 12:49 PM
The Old Man
Oh...Thanks I thought that it was a new part number that did not have the brake lights set up that way. Works now so I am happy.
Old 04-07-2009, 08:49 PM
Mick's Avatar
Mick
Mick is offline
Is the new tail light 3 or 4 times brighter than the stock one or the Harley LED part?
I was talking to Keith about the tail light and I'll probably get one , I was ordering the rear glide lights and FlashR setup at the time.
The tail light looks like a great deal and I was curious as to the intensity of it.
I went with the Badlands brake/running light/load equalizer with the thinking that I would replace most lights with LED over time.
So far I like his stuff.
Mick
Old 04-07-2009, 08:54 PM
ms3300's Avatar
ms3300
ms3300 is offline
if you really wanna light up that rear end, look into his fender tip tail/brake light..that is a nice accessory. i installed one on my 08 egc a few mos back and love it. it is a direct plug in play replacement for that dim little fender tip light that is currently there. makes a much brighter running light and illuminates as a brake light too. all this and was an ez install.
Old 04-07-2009, 11:59 PM
dgretz's Avatar
dgretz
dgretz is offline
+1 on the ridetime LED tailights. Have them on our SG and XL.
Old 04-08-2009, 05:45 AM
The Old Man
Mick
yes 3 or 4 times brighter.........and a very easy install.
Old 04-08-2009, 06:18 AM
StreetGlideMedic's Avatar
StreetGlideMedic
StreetGlideMedic is offline
The Old Man...Sounds great you had an awesome experience! Always nice to hear the positive when something unexpected happens!
Ride Safe, Mike
Old 01-05-2010, 04:27 PM
big_e78's Avatar
big_e78
big_e78 is offline
Does the Harley run-turn-brake module work with the ridetime LED tail light
setup?
Old 01-06-2010, 03:03 PM
The Old Man
Yes it does...no change in any operation......
Quick Reply: Ride Time Tech LED tail light
