Odometer D02 SET
Odometer D02 SET
If you hold the trip reset and turn the ignition on you get a set of codes on the odometer readout. I'm searching for what these codes mean but can't find them anywhere. Right now, my readings show:
D01 CLR
D02 SET
D03 CLR
D04 CLR
D05 CLR
D06 CLR
D07 CLR
D08 CLR
D09 CLR
D10 CLR
PPU
I assume that D02 SET means a code has been set. In my searching, I found no reference to these codes. My 03 Fat Boy is carb'd.
D01 CLR
D02 SET
D03 CLR
D04 CLR
D05 CLR
D06 CLR
D07 CLR
D08 CLR
D09 CLR
D10 CLR
PPU
