max cruise speed on 883 iron?
Old 04-04-2009, 11:32 AM
uer 84038's Avatar
uer 84038
uer 84038 is offline
why would it even be considered that running at 80 would damage the motor?
Old 04-04-2009, 02:45 PM
cHarley's Avatar
cHarley
cHarley is offline
Originally Posted by Wpittman
so 138 rpm reduction not really worth the bucks?
Not IMO. At 75 the drop in RPM is the equivalent of slowing down about 2 mph. Now, if you were to change the complete gear set, primary & secondary, to that of a 1200, your talking about a 500+ RPM difference at 75.
Old 04-04-2009, 06:47 PM
uer 84038's Avatar
uer 84038
how much would that cost?
Old 04-04-2009, 08:25 PM
7/11 The Crapshooter's Avatar
7/11 The Crapshooter is offline
The 883 is geared lower than the 1200. The chart below details the RPM vs. speed in each gear. While 5th gear "theoretically" tops out at 110 mph, real world factors such as rider weight, baggage, drag, etc. will cause you to run out of HP before you reach red line in 5th gear.
The gear differences between the 883 and 1200 involves both primary and secondary gears. Changing from a 28T to a 29T only, will reduce your RPM by a factor of .9655 or 3.45%. 71 MPH at 4000 RPM will drop to 71 MPH at 3,862 RPM, for an RPM decrease of 138 RPM.
I don't know where you got that chart Charley but I have a gearing calculator that indicates the 883 with a 28T front sprocket at 3,600RPM in 5th gear is going 67.2mph and a swap to the 29T will move it up to 69.6mph and the 30T will move it up to 72mph at that same 3,600rpm. The chart puts the bike at 64mph while going 3,600 in 5th. The final changes from 2.42 on the 28T to 2.34 on the 29T and 2.26 using the international 30T. The 1 tooth change in the front is worth almost 4 teeth on the rear and on my 1200 the 29T swap to the 28T was worth roughly 350rpm observed on the tach read out at 60mph. Granted the 1200 is running a primary of 1.5:1 whereas the 883 is 1.67:1. I saw this chart for a 1200 and could never get it to match up with the tach on the bike. I checked the tach at 70mph today and it was heads up at 3.300rpm. The calculator I am using says it should be 71mph at 3,300 so I figure an error factor of roughly 1.5% is close enough. If the drop in rpm were only 138rpm people wouldn't be making the change to the 29T as it would be useless to them and this simply isn't the case as some folks I know have made the swap and done pretty good when going to the big bore kit without changing to the 1200 primary.
Old 04-04-2009, 08:31 PM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
When my Sporty was a stock 883 cruised at 80 nicely would do 100+ but the vibration and strain on it was not good ..
Old 04-05-2009, 01:48 AM
Azwethinkweiz's Avatar
Azwethinkweiz
Azwethinkweiz is offline
Ive been over 120 mph on my sportster and my buddy has an 883 and he's just fine ripping down the highway with me....He's never bitched about bad vibrations or anything like that, but it does stop accelerating at like 105 lol.
I think its funny every time HD cuts a fender and paints parts black on a sportster, people act like its a whole new bike and specify it as such...(Ex: Nightster and new Nighty Light)
Old 04-05-2009, 01:25 PM
BWLucky13's Avatar
BWLucky13
BWLucky13 is offline
Default Ditto to Ashenfang
60 mph cruiser great for faster rips where desired. Here is my take on favorite bikes:
Town scoot: Yamaha 250 40mph
Burb commuter: Suzuki 40 single 50mph
Best standard: 883 Sportster 60mph
Super slab eater: Road King 70mph
No bike is best of everything. The little Yamaha will do 80, but not with me on it. Nothing is more fun up to 50 than a thumper, but then it's out of breath. Sportster is THE standard, but that doesn't make it a great scooter or a superslab boat. Enjoy the ride.
Old 04-05-2009, 01:48 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
I know it's a little 'OT', but those little thumpers are great fun for running around in nasty stuff.
Good friend of mine has a Suzuki DR650 that I've ridden many times. It will do an honest 100 MPH, and is perfectly happy cruising at 70 to 75 all day long.
Guy more of less gave me a slightly modified Honda XL250S a few months ago which pulls about 28 or so horsepower at a 'wet weight' of only 275 pounds. Damn little thing will pull a wheelie in 1st, 2nd, and 3rd, and I've had it up to an indicated 80 MPH before I came to my senses. It's more happy cruising in the 60 MPH range, and it's great fun for using on the dirt/gravel/mud roads around here.
Nothing beats a good Harley for highway cruisng, but those little lightweight thumpers have a good power to weight ratio and are just plain fun. Besides that, no chrome on them to worry about getting dirty. Just hose them off every once in a while and they are happy.
Old 01-11-2011, 03:21 PM
Elenagym's Avatar
Elenagym
Elenagym is offline
Stage II
Wink Max speed for Iron 883
I hit on my 2010 Iron883 185km/h with no vibrations,can't check max acceleration - radar ahead!
Installed SE exhaust system and Screamin' EagleŽ Street Legal "Heavy Breather".
Old 01-11-2011, 04:08 PM
veritas.archangel's Avatar
veritas.archangel
veritas.archangel is offline
Max cruise speed would depend mostly on what the speed limit is.
Quick Reply: max cruise speed on 883 iron?
