Cruise Control Issues
Old 03-21-2009, 09:23 PM
bryce95racing's Avatar
bryce95racing
bryce95racing is offline
Default Cruise Control Issues
I have an 07 Road King Classic. I took it out for the first time today, since I live in Minnesota. My Cruise Control is not working properly. It only works once and a while. Does anyone have any idea what the problem might be?
Old 03-21-2009, 09:38 PM
beary's Avatar
beary
beary is offline
One possibility is a failing Speedometer sensor. You would know it by the speedometer acting funny and the blinkers not working at the time of the failure. It wouldn't want to idle either. Also check the connections of your Roll Off cable. Those are the two connectors at the right side of the neck of the frame between the gas tank and triple tree. IF they aren't getting good contact, they can fail the system. Just pull them apart and plug them back together.
Now those are things I would expect on an 02, I'm guessing the 07's are about the same.
Beary
Old 03-21-2009, 09:48 PM
takeiteasy's Avatar
takeiteasy
takeiteasy is offline
When you say it does not work what do you mean?
With the cruise control on my 07 SG you have to let the cruise control "catch up". Or it will shut off.
pxs130's Avatar
pxs130
pxs130 is offline
+1 on the roll-off switch. Replaced my idle cable this winter and dont have any more problems. I've heard that you can disconnect one of the connections to fix the problem, but I ended up replacing the whole cable.
Old 03-21-2009, 09:52 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
This is a helpful thread for diagnosing cruise control problems:
https://www.hdforums.com/forum/engin...and-codes.html
Old 03-21-2009, 09:54 PM
beary's Avatar
beary
beary is offline
Good suggestion, I forgot about that. Actually I think you can disconnect both of them and it will work if the roll-off switch is the problem. You just won't be able to turn off the cruise off from the throttle.
Beary
Old 03-21-2009, 09:58 PM
bryce95racing
Thanks for the replies. i just tried the cruise diagnosis, but, it would not work. my brake light keeps coming on, and i can hear clicking from around the seat area. my brake light stays on also, so i am wondering if its not the wiring itself.
Old 03-21-2009, 10:38 PM
OG1's Avatar
OG1
OG1 is offline
do you happen to have a HD run turn brake module? i did and when i had a bulb go out all hell broke loose TSSM went ape**** and the run turn module would just sit there and click. i cant say if it affected my cruise because i never tried it when i was having the issue, but the TSSM reset procedure cured my problem. might be worth a shot fr you if you do have a run turn brake module.
Old 03-21-2009, 10:55 PM
D2R's Avatar
D2R
D2R is offline
Make sure there's no gap between your front brake lever / master cyl. ***. and the twist grip ***.same thing happend to me after I mounted my sirius radio on the handlebar there's a micro switch that the brake lever holds down if ther's a gap there the switch won't have enough pressure on it.I had a problem with my cruise going off intermittently like every time I hit a bump.A buddy behind me said my brake light was flashing. You could jiggle the brake lever and get the brake light to stay on solid.(This is on my 08 eglide the 07 might be set up different.)
Old 03-22-2009, 08:41 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
If the '07 is like the '06,there is a cable that connects to the throttle body and the cruise control module.When I had to replace the throttle cable on mine I lubed the criuse control cable.Would be a good idea to check the cable.
There is also a cable adjustment and cable lash initialization procedure.
A service manual would be a big help.
Quick Reply: Cruise Control Issues
