How "Reserve" Fuel Works on a Carbed Bike
Old 03-19-2009, 05:43 PM
cHarley's Avatar
cHarley
cHarley is offline
Default How "Reserve" Fuel Works on a Carbed Bike
There seems to be a number of people here that believe that there is a separate section in the fuel tank where the "Reserve" fuel is stored. I hope this clears it up for you guys.
There is no separate reserve, section, divider, compartment, etc. in the fuel tank.
The petcock pickup tube has 2 fuel holes, one for the normal ON position (upper hole) and one that's used when you switch to the reserve position (lower hole). Once the fuel level drops below the upper hole, you are out of fuel until you switch the valve to Reserve which opens the lower hole.
OK, it's a quick and dirty drawing but it shows how the reserve works.
Old 03-19-2009, 06:03 PM
WarriorHD's Avatar
WarriorHD
WarriorHD is offline
Good example, which is also exactly the reason why it's risky riding with the petcock in reserve mode all the time. When you do this, once you're out, you're out.
Old 03-19-2009, 06:26 PM
eazyrider's Avatar
eazyrider
eazyrider is offline
Good info I did not know that.
Old 03-19-2009, 07:21 PM
TestFlyer's Avatar
TestFlyer
TestFlyer is offline
Thanks cHarley, for emphasizing the extreme 'crudeness' of this otherwise perplexing system....
Old 03-19-2009, 07:55 PM
RATROD HOG's Avatar
RATROD HOG
RATROD HOG is offline
here ya go
1-pic OFF
2-pic ON
3-pic RESERVE
4-white thing is filter for who never seen one
Attached Thumbnails How "Reserve" Fuel Works on a Carbed Bike-fuel-valve-001.jpg   How "Reserve" Fuel Works on a Carbed Bike-fuel-valve-002.jpg   How "Reserve" Fuel Works on a Carbed Bike-fuel-valve-003.jpg
Old 03-19-2009, 08:18 PM
weenpeace's Avatar
weenpeace
weenpeace is offline
Good gouge. Appreciate the info.
Old 03-19-2009, 09:57 PM
freekdawg1200's Avatar
freekdawg1200
freekdawg1200 is offline
Thanks for clearing that up!The only thing I don't like about my Pingel fuel valve is it doesn't have cam indentions for the lever.It's smooth as butter,but finding reserve on the fly is is tricky!
Old 03-19-2009, 10:25 PM
ape.hanger883's Avatar
ape.hanger883
ape.hanger883 is offline
i have only had to switch to reserve once down the main street in my city. Did not know bike was sputtering though as I was gearing down to stop at a red light and once almost stopped she died. Hit it to reserve and was away just at the right time.
Old 03-19-2009, 11:48 PM
congo_usmc's Avatar
congo_usmc
congo_usmc is offline
great info, thanks i was not aware how it worked
Old 03-20-2009, 01:14 AM
HDXXX's Avatar
HDXXX
HDXXX is offline
Only once did I run completely out of fuel. I wasn't close enough to make it to a gas station on the reserve. Hopefully never again.
Quick Reply: How "Reserve" Fuel Works on a Carbed Bike
