Car tire on an Electra glide???
Old 03-17-2009, 12:49 AM
hatchetman's Avatar
hatchetman
hatchetman is offline
Default Car tire on an Electra glide???
Anyone here running a car tire on their bagger? I want to know more about it.
I need a new back skin this summer so Im snoopin' around for the best way to go.
Thanks.
Old 03-17-2009, 05:51 AM
timvan's Avatar
timvan
timvan is offline
Joke right? April 1st is next month.
The Old Man's Avatar
The Old Man
The Old Man is offline
I have heard of it being done but as much as it would be nice to get the extra milage out of the rear I would avoid it myself. There is a difference in the bead area between the bike and car rim. The car, I believe needs more bead area then you bike rim has. Could cause leakage or worst. Hate to have low pressure and have the bead pop in on a corner. This is just my opinion and like belly buttons every body has one..........
Old 03-17-2009, 05:59 AM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
google "dark side." Running a car tire is known as "going over to the dark side." There are whole web sites devoted to it. With the new wider back wheel on the '09's, you will probably start seeing it on Harley's. Wing and Valkrieye riders seem to be the ones I've seen it on.
Old 03-17-2009, 06:01 AM
MNPGRider's Avatar
MNPGRider
Old 03-17-2009, 07:58 AM
Tharber's Avatar
Tharber
Tharber is offline
Car tires have more of a squared off edge leading to the sidewalls versus a bike tire. Your bike rides the outer sides of the tire while turning, car tires would make this very hard IMO.
Tim
Old 03-17-2009, 08:27 AM
XTrooper3936's Avatar
XTrooper3936
XTrooper3936 is offline
Just say no.
You can afford to have tires with rock-hard compounds and 80,000 mileage warranties when you're in a car and riding on four of them. On a bike, I want a stickier tire, rounded sidewalls, and mileage be damned.
jasle (07-24-2021)
Old 03-17-2009, 08:41 AM
77Tulsa's Avatar
77Tulsa
77Tulsa is offline
On my next project bike I plan on doing a car tire on the back and a cop rear tire on the front. Everyone gets stuck on doing what the MOCO thinks they should be doing instead of customizing and going out side of the box. I say if it is different and you like it go for it!
Old 03-17-2009, 08:55 AM
ord sgt's Avatar
ord sgt
ord sgt is offline
Saw a video on you-tube about this subject. Someone mounted a video camera so the rear tire could be observed while in motion. In turns the sidewall flexes and the tread stays in contact with the road. Old school.
Old 03-17-2009, 09:01 AM
Geoff's Avatar
Geoff
Geoff is offline
A car tire's squared off edge will affect handling in corners. Car tires are suitable only for trikes, hacks and other bikes that don't lean.
Quick Reply: Car tire on an Electra glide???
