CRANKCASE DRAIN PLUG
Old 04-11-2005, 02:15 AM
PORKCHOP's Avatar
PORKCHOP
PORKCHOP is offline
Stage III
Default CRANKCASE DRAIN PLUG
IN DRAINING THE ENGINE OIL FROM A SOFTAIL, I REALIZE THAT YOU ARE SUPPOSED TO DRAIN ONLY THE OIL TANK, BUT WHAT IS THAT DRAIN-PLUG LOOKING BOLT UNDERNEATH THE CRANKCASE ON MY 2005 FXSTS?
Old 04-11-2005, 08:27 AM
pococj's Avatar
pococj
pococj is offline
Default RE: CRANKCASE DRAIN PLUG
Don't mess with it. While it might be a "drain" plug, ya don't take it out when changing oil. Basically there is no oil in the crankcases on a harley, unless the oil pump check valve fails. And then when you fire it up, it'll puke all the oil trapped in the crankcase out the breather, and/or pump it back into the tank.
Old 04-11-2005, 11:57 PM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
been there dun that, got oil on my jeans, pissed off the mate when i chucked em tn the laundry basket!
Old 04-12-2005, 12:50 AM
hawk's Avatar
hawk
hawk is offline
You need to get a shop manual,It will keep you from doing naughty things to your scoot
Old 04-12-2005, 02:04 AM
Lovetoride's Avatar
Lovetoride
Lovetoride is offline
ORIGINAL: hawk
A wise man indeed...
Old 01-11-2010, 05:42 PM
JustDave71's Avatar
JustDave71
JustDave71 is offline
OOOOLD thread but instead of starting a new one I thought I'd bump
S&S cases...ok so the plug aint for drainin oil
what's it for then?
splittie65
EVO
23
08-21-2018 09:41 AM
lebert
Oil Archive (no new posts)
08-14-2012 05:13 AM
GPHDXLC
Exhaust System Topics
06-27-2011 04:43 PM
roadrashron
09-22-2010 04:39 AM
tjr63pa
02-28-2010 01:20 PM
Quick Reply: CRANKCASE DRAIN PLUG
