Headquarters TC-500-HC vs Harley SE-204 cams?
Old 03-07-2009, 07:09 AM
XTrooper3936's Avatar
XTrooper3936
XTrooper3936 is offline
Default Headquarters TC-500-HC vs Harley SE-204 cams?
I'm currently running a 103 with stock cams. I do a lot of heavy, 2-up riding and it's for this kind of riding I want my cam choice to most improve. I have a fairly mild riding style and normally shift at between 3000 and 3500 rpm. Rarely will I shift over 4 grand. Anyway, after a lot of research, I've decided to go with either a set of HQ TC-500-HC "Hurricanes" or H-D SE-204s.
In your opinion, do one of these cams hold a clear advantage over the other for the kind of riding I do? If you were in my shoes, which would you choose between the two and why?
Thanks in advance for your comments and opinions.
Old 03-07-2009, 07:17 AM
masterblaster's Avatar
masterblaster
masterblaster is offline
Steve I had the 500 in my 07 RKC, tq shot staright up at 2k and stayed flat til 4500, you might want to look at the new hq 525, I was just looking at their site after reading a Phil M thread.
Old 03-07-2009, 07:23 AM
XTrooper3936
Thanks for the advice, but it was Kevin himself who recommended the 500s to me. Keep me mind, my motor never sees 4500 rpm.
Old 03-07-2009, 07:46 AM
ga4boats's Avatar
ga4boats
ga4boats is offline
Steve, you may want to check out the Latus HD forum (to post a question it costs $4.95 for one month's access). Mike has some real good advice and they also have some good Dyno charts. I found him to be very knowledgable and quick to respond to my questions.
Old 03-07-2009, 07:54 AM
XTrooper3936
Mike's advice might be great, but I haven't paid for posting a question to date and I'm not about to start now. I'm never going to pay to listen to the radio either (XM et al), but that's just me.
Comments regarding personal experiences with one of these two cams would be helpful.
Old 03-07-2009, 08:13 AM
molsen's Avatar
molsen
molsen is offline
I would look at the ealier timing opening and duration that helps the tq. HQ-500 are a great choice, also look at woods tw5-6 or tw6-6. Seeing you do not rev your scoot so much, you can use .575 lift with your stock beehive springs. I did that with my hq575 before I could swing the 103 kit. I personally do not like the intake timing on the SE-204, jmo.
Old 03-07-2009, 10:57 AM
XTrooper3936
Thanks for the input, Molsen. I appreciate it.
I didn't mention this earlier because I didn't want to trigger the "Pygmalion Effect," but I'm leaning towards the HQ cams.
Old 03-07-2009, 11:38 AM
Dr. Combustion's Avatar
Dr. Combustion
Dr. Combustion is offline
I had the 204 cams installed with my 103 kit. The cams pull strong from 1800 rpm and up. My motor now quickly revs to 5000rpm (my limit to date), and I am impressed with the setup. My only other experience is with the 255 cams, and I will take these 204 any day over the 255s, especilly if you spend time above 2400rpm. Mine was the first combo to be installed by my dealer, and he now recommends the 204s over the 255s with the 103 upgrade.
As a reference, the 204s have very similar lift and duration as the Andrews 31 or 37, but the timing events are different for all three.
Old 03-07-2009, 11:53 AM
XTrooper3936
The SE-204s definitely have a lot going for them in regard to what I'm looking for which is exactly why they're still in the running. Thanks for your impressions, Doc.
This is really becoming a hard decision for me. I've been back and forth between these two cams a dozen times.
Old 03-07-2009, 12:04 PM
molsen's Avatar
molsen
molsen is offline
Look at the intake timing, the lower degree opening the better it is for low end tq and low rpm operation. It does not matter whose cam, but the timing specs will help out a lot. Woods/HQ use early timing for better tq.
Quick Reply: Headquarters TC-500-HC vs Harley SE-204 cams?
