how to adjust throttle cables/clutch
Old 03-04-2009, 02:36 PM
sledhead140's Avatar
sledhead140
sledhead140 is offline
Default how to adjust throttle cables/clutch
can anyone tell me how to correctly adjust my throttle/idle cables and also my clutch cable? i just installed my apes now just need to mount my cables.
thanks
Old 03-04-2009, 02:56 PM
m i k e's Avatar
m i k e
m i k e is offline
got service manual?when you adjust throttle /idle when you
twist it it needs to freely go back w/out binding
clutch is pretty much how you like loose or firm
Old 03-04-2009, 03:30 PM
hellfish's Avatar
hellfish
hellfish is offline
I cant get there at work now to post a link but if you look on youtube there is a video. On the clutch cable you'll see a rubber cover, you slip that off, loosen teh nut holding the longer threaded cable in place and once that is loose you can rotate the longer threaded piece. The spot I prefered was adjusting it to where there was about a nickle worth of space between the level and the housing.
Old 03-04-2009, 07:30 PM
ronyd's Avatar
ronyd
ronyd is offline
do a search on this forum. There's a few good explanations on how to do adjustments.
Old 03-04-2009, 07:38 PM
tlb's Avatar
tlb
tlb is offline
Old 03-04-2009, 08:29 PM
PureDeath's Avatar
PureDeath
PureDeath is offline
That's a great site, thanks for the info!
Old 03-04-2009, 08:31 PM
Joe What's Avatar
Joe What
Joe What is offline
the throttle adjusters are where there are two rubber covers as the cable leaves the throttle housing.. move the rubber covers up or down and you will see two nuts adjust accordingly. The cluth cable as stated by hellfish.. hope this helped
Old 03-05-2009, 07:13 AM
tlb's Avatar
tlb
tlb is offline
no problem good luck
HD-1
04-25-2017 07:52 PM
steelerdude1
05-22-2014 11:04 PM
fatboy slim
Exhaust System Topics
01-06-2014 08:06 AM
traveler
12-31-2011 12:20 PM
cjbmustang
05-26-2010 08:50 AM
Quick Reply: how to adjust throttle cables/clutch
