The best oil cooler for my 'bob?
Old 02-24-2009, 04:33 PM
Bad Example's Avatar
Bad Example
Bad Example is offline
Default The best oil cooler for my 'bob?
I often ride in heavy traffic and the engine does heat up considerably. It seems like the 3rd party vendors may be offering superior products. Any advice or experience here?
Old 02-24-2009, 05:01 PM
r00k's Avatar
r00k
r00k is offline
Could get a larger oil cooler or XiEDs
Harley sells a larger oil cooler for the touring bikes and nightrider.com sells the XiEDs for $100.
XiEDs are cheaper and easy to install.
Old 02-24-2009, 06:07 PM
luckyB's Avatar
luckyB
luckyB is offline
Jagg makes good oil coolers. Donny Petersen has written a bit lately about them lately in American Iron magazine... he seems to be a fan too.
http://www.setrabusa.com/jagg%20file...s/jagghome.htm
Old 02-24-2009, 06:20 PM
dope_man_21's Avatar
dope_man_21
dope_man_21 is offline
I purchased the Milwaukee Twins Dual Cool II oil cooler for my bike, but have not gotten around to installing it yet, I have so many projects that are incomplete.
Old 02-24-2009, 06:29 PM
2002fxdp's Avatar
2002fxdp
2002fxdp is offline
i got the 10 row Jagg but its not on yet since theres no engine in there either.
did a a bit of research before buyin, and it was my best option as far as i'm concerned
Old 02-24-2009, 07:04 PM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
I got the Harley Davidson 10 row oil cooler kit which I believe is made by Jagg. Unfortunately I don't have a temperature gauge to compare before and after temps. If the cooler isn't enough for your set up you may also look into installing a fan triggered by the front brake light circuit.
I got mine brand new off eBay for $149.99, a lot cheaper then the Jagg set up. Here's some more info and photos: https://www.hdforums.com/forum/dyna-...il-cooler.html
Old 02-24-2009, 07:16 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,309 Likes on 2,356 Posts
I've got the verticle mount coolers from Jagg mounted to the left down tubes on both of my Dyna's. I'm quite satisfied with the performance of both. One has the automatic thermostat and the other doesn't. Not a big fan of coolers mounted across the bottom of the frame where debris off the front tire is going. Synthetic oil is a good bet for you also.
Old 02-24-2009, 08:00 PM
rdondes's Avatar
rdondes
rdondes is offline
I've read all the articles on the Jagg 10 row. I'm convinced it's the best.
Old 02-24-2009, 09:38 PM
mud's Avatar
mud
mud is online now
muderator
Received 8,777 Likes on 2,064 Posts
I picked the 14 row for my 121.
mud.........
Old 02-24-2009, 10:18 PM
WS6 Formula
rdondes,
Did you compare them to others offered from different manufactures?
Jagg P/N 2500
The Jagg 10-row Low mount Oil Coolers are designed for TC-88" and TC-96" Harley-Davidson Dyna motorcycles. The #2580 adds a CNC aluminum deep-chromed accent along the visible portion of the cooler. This compact unit offers 40 percent greater cooling capacity than the already high-performing Jagg 6-row cooler. A unique mounting system insures easy installation. The cooler's special in line turbulators and mini-louvered air fins insure unparalleled efficiency.
http://www.setrabusa.com/jagg%20files/jagg%20pages/10-row-dyna-lowmount.htm
Harley Davidson Premium Oil Cooler Kit P/N 26110-05
This cooler was designed specifically for Harley-DavidsonŽ to out-perform all other coolers in the industry. This cooler features a unique "Turbulator" system that evenly distributes oil across the cooling chambers. The air fins are designed to efficiently dissipate heat. This popular oil cooler has been re-designed to simplify installation and enhance performance. The larger heat exchanger provides additional cooling efficiency. Kit features an adapter plate with integrated thermostat that allows oil lines to connect to the oil filter bracket. The thermostat activates at 185°F (85°C). Kit comes complete with mounting hardware and precut oil lines. Kit includes Chrome Oil Cooler Cover.
Quick Reply: The best oil cooler for my 'bob?
