SE 255 Cams with stock displacement .... Money well spent?
Old 02-17-2009, 11:31 AM
Concrete Cowboy 2009's Avatar
Concrete Cowboy 2009 is offline
Default SE 255 Cams with stock displacement .... Money well spent?
I am getting close to ordering a new Road King, and I want a little more punch from the throttle. Obviously, a SERT, breather, and pipes, but what about a cam upgrade? Id rather not spend the money for the 103 if the difference is not going to be that great. I'm stumped... Help!
SE 255? SE 257?
Any advice will be appreciated.
Old 02-17-2009, 11:42 AM
KoalaCowboy's Avatar
KoalaCowboy
KoalaCowboy is offline
From posts I've read, with a stock TC96, you're better off with the SE211 cam (if memory serves).
Here are a few threads:
Thread 1
Thread 2
I just did a search in the Touring Forum for SE211 and came up with 33 threads...
Old 02-17-2009, 11:46 AM
wbeem's Avatar
wbeem
wbeem is offline
This is over my head, but there's a good discussion of cams and performance on the Dyna forum. Perhaps it will give you some useful info.
https://www.hdforums.com/forum/dyna-...o-results.html
Old 02-17-2009, 11:48 AM
jensen's Avatar
jensen
jensen is offline
good question, i'm interested in the answer also....
HDRider2002's Avatar
HDRider2002
HDRider2002 is offline
If you want to stick with HD cams due to warranty concerns, you have plenty of reading to do there. If aftermarket is ok with you, the HQ-500 seems to be the way to go. You will certainly get alot of responses from individuals that have used one cam or another, definately no shortage of options out there.
Old 02-17-2009, 12:00 PM
cowboy1's Avatar
cowboy1
cowboy1 is offline
I went with the SE 260 cam but did head work, big bore and pistons as well...are you planning on just doing a cam? If so, you won't be getting your moneys worth. You should at the very least do pipes, air kit and tuner.
Old 02-17-2009, 12:04 PM
stro1965's Avatar
stro1965
stro1965 is offline
I'll be installing Andrews 26H cams in my 96", hopefully next week. Stay tuned!
Old 02-17-2009, 01:53 PM
I am planning on Pipes, probably V&H Big Radius Touring, Screming Eagle Ventilator Breather, and SERT.
I am concerned about the warranty.
What about the SE 110 kit, is it worth the money? What does it cost?
Old 02-17-2009, 02:02 PM
stro1965's Avatar
stro1965
stro1965 is offline
Seem to be a lot of issues with the SE 110, running hot and leaking oil at the base of the rear jug. 103"-yes, 110"-no. IMHO.
Old 02-17-2009, 02:39 PM
wbeem's Avatar
wbeem
wbeem is offline
My dealer also steered me away from the 110 toward the 103. Although they claimed the 110 issues seemed resolved by the '09 year, they had more experience with the 103 and felt confident the systems they put together with that kit would outperform the CVO 110 bikes.
Also, it's less expensive. Unless you absolutely have to get the 110, check out what you can do with a 103. You may get more bang for the buck and less headache after the fact.
Quick Reply: SE 255 Cams with stock displacement .... Money well spent?
