street glide rear shocks??
Old 02-06-2009, 03:59 PM
salty01's Avatar
salty01
salty01 is offline
Default street glide rear shocks??
Anybody have experience and can recommend a good replacement shock??
For 2 UP riding on a trip with tbag.
OEM seems harsh at times..22 day trip this summer .
Dont want the SLAM on the fly kits though.
Thank you!
Old 02-06-2009, 04:03 PM
skratch's Avatar
skratch
skratch is online now
Received 4,191 Likes on 2,457 Posts
really, for the best ride, if you can swing it, just for the trip, is to replace the street glide shocks with almost anything that is stock length for the other touring bikes (ie 13 inch). that extra inch of travel will add greatly to your comfort level, even if they are stockers from another tourer.
Old 02-06-2009, 04:09 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
Progressive
Old 02-06-2009, 05:07 PM
edellavedova's Avatar
edellavedova
edellavedova is offline
Penske shocks - check out motorcyclemetal.com. Provides an amazing change to the ride quality - and since they're adjustable - you can set them for 2 up or solo riding.
Good luck.
Old 12-15-2010, 05:27 PM
ihitman's Avatar
ihitman
ihitman is offline
Wow, those Penskes are pretty pricey.
Old 12-15-2010, 05:46 PM
boom23's Avatar
boom23
boom23 is offline
The cheapest way is to get a used set of 13" Harley touring shocks. They work great and they are many of them around...
Old 12-15-2010, 08:29 PM
RK14SGS's Avatar
RK14SGS
RK14SGS is offline
Assuming the air pressure has been checked and adjusted appropriately, correct?.... Our local dealer let at least 3 touring bikes out with only 5 psi air in the shocks... found it on a long ride when one of us bought a pump on sale, and checked his... Then we checked bike #2, same thing.. bike 3 also same thing....
Old 12-15-2010, 08:40 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
Thank you!
I've had Progessives and although better than stock I prefer the Works Street Trackers.
Rick
Old 12-15-2010, 09:43 PM
Cme2c's Avatar
Cme2c
Cme2c is offline
2nd that on the stock 13" eglide shocks. You can pick up an almost new pair on eBay for under $100 and the difference in ride comfort is amazing. I'm sure the Penske & Ohlins shocks are better but they surely can't be $500 better!
Old 12-15-2010, 09:59 PM
legendzzz's Avatar
legendzzz
legendzzz is offline
How much do you want to spend ? Get the Progressives($500) 940 , they are 12" shocks that give you the ride of a 13" shock. It sounds confusing but it really works. I took the cheap way out , I wanted a lower bike so I bought a 12" air shock from the HD OEM brand. Now it sits on my UC. I like the lower shock and seat so I can get to a better handling posistion with 2 up and packages and 900 + lbs to balance , YEA get me close to the ground !!
Quick Reply: street glide rear shocks??
