Help!! Softtail Rear wheel removal/installation!!
Old 01-21-2009, 08:54 AM
ckamin's Avatar
ckamin
ckamin is offline
Default Help!! Softtail Rear wheel removal/installation!!
In an effort to work on my own bike and save some $$$ at the same time, I want to r&r my rear wheel since it needs a tire. Couple questions.....
1) I have a '06 Springer Classic... will your typical Craftsman-style jack raise the bike high enough to remove the rear wheel from the full rear fender?
2) Any suggestions for replacing the tire and making sure that the belt is properly adjusted and that the rear whell is aligned? Does one mark the adjusting bolts on the swingarm prior to removing the wheel prior to removal so that they can be re-adjusted to their previous position?
Before going on a few trips in the spring, I want to replace my rear tire. I have about 8000+ miles on the bike, so this will be my first rear wheel r&r on a Softtail.
Thanks!
Carl
Old 01-21-2009, 09:12 AM
chillman9's Avatar
chillman9
chillman9 is offline
I would suggest you start with a repair manual for your bike...easy to follow instructions on removal and reassembly with all the proper adjustments.
Old 01-21-2009, 09:15 AM
ckamin's Avatar
ckamin
ckamin is offline
Yeah, I have the service manual and have read it, but I was looking for the "real world" advice that service manuals usually lack. The H-D book is pretty good, but it is still a corporate publication.
Old 01-21-2009, 09:29 AM
chillman9's Avatar
chillman9
Thanks!
Carl
*raise the bike on the jack to see if the fender is high enough to clear the tire hieght...i'm not sure with this style jack
*I have heard of guys just marking the adjusting bolts and counting the turns out and then just adjusting them back the same amount....be sure you take note of where your spacers are and would be a good idea to repack the bearings while you have the wheel off.
Old 01-21-2009, 09:31 AM
softail04's Avatar
softail04
softail04 is offline
the way I have been doing it for years is
remove lower belt guard (left mine off) remove axel, put it back in from left side so you don't have to remove exhaust next time.. leave the belt adjustment alone and drop the rear wheel straight down (never have to touch belt adjustment. worst part is getting the calipher back on .. I have a std but they are all much the same
Old 01-21-2009, 09:38 AM
chillman9's Avatar
chillman9
Old 01-21-2009, 12:37 PM
ckamin's Avatar
ckamin
ckamin is offline
Thanks for the advice! The link to the other thread proved helpful, too.
-Carl
Old 01-21-2009, 01:22 PM
rcc's Avatar
rcc
rcc is offline
Softail04 has it right, don't touch the adjustment screws. You can get the belt off and on without messing with them. I use the yellow Sears jack on my Heritage. I also use a floor jack and support the tire and lower it on the floor jack. Put the axle in backwards like he said.
Ron
Old 01-28-2010, 10:09 PM
kiwideuce's Avatar
kiwideuce
kiwideuce is offline
some great advice there i will find useful too
billbrummett
08-08-2018 05:13 AM
Dozer1
01-29-2010 07:02 PM
gplarryv
04-02-2009 09:17 AM
ken thompson
04-15-2007 01:49 PM
WarriorHD
03-16-2007 08:13 PM
Quick Reply: Help!! Softtail Rear wheel removal/installation!!
