what kind of oil in an ironhead
Old 01-06-2009, 10:30 AM
emtjayb's Avatar
emtjayb
emtjayb is offline
Default what kind of oil in an ironhead
i know this prob has been asked 100 times before but what type of oil should i be using for my ironhead?
Old 01-06-2009, 12:04 PM
83XLX's Avatar
83XLX
83XLX is offline
You'll probably get as many different answers as posts, but here's my take: If it's cold most of the time, like below the mid 50's, I'd run 20w50. If it's warmer than that, I'd run straight 50wt or 60wt. I have mixed 20w50 and 60wt when the temps were in both extremes, but I'm not sure how much good that does. Basically you want to use the thickest oil that's suitable for the air temps you'll be encountering. Too thick, and your bike won't want to turn over when cold and the lubrication will be marginal 'till the oil warms up. Too thin, and your motor will run hot and be more noisy, which is probably an indication of excess wear occurring. Also, your best bet is to use a petroleum-based oil (not synthetic) that's made specifically for Harleys.
Old 01-06-2009, 05:19 PM
shepdog's Avatar
shepdog
shepdog is offline
i run straight 50 or 60 wt. way to noisy with 20-50
Old 01-07-2009, 12:15 AM
sepixlh's Avatar
sepixlh
sepixlh is offline
If temp is mainly under 90F I'd run 20W-50
Old 01-07-2009, 01:47 AM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
Mine has had nothing but Pennzoil 20w-50 in it for the past 30 years.
Old 01-07-2009, 08:40 AM
emtjayb's Avatar
emtjayb
emtjayb is offline
Thanks for the help.
Old 01-08-2009, 06:45 PM
hog4u's Avatar
hog4u
hog4u is offline
Default I know you have your answer already..but
I run whatever I have in my Truck. Recycle from Truck to Motorcycle to Lawn tractor. I wouldn't put used oil in my chainsaw, a man has to have principals.
Pat
Old 01-09-2009, 12:11 AM
sepixlh's Avatar
sepixlh
sepixlh is offline
Pat
You aren't serious, used oil on ironhead.... why you don't just pour sand in oil tank ? it's much easier way to destroy your engine. Oil isn't so expensive that you can't buy it, if you can't afford it sell your bike.
Old 01-09-2009, 02:35 AM
xxxflhrci's Avatar
xxxflhrci
He may not be serious, but we do use "used" oil in our tractors. My dad's work place has an extremely large Cat diesel generator that gets ran 20 minutes or so a week for testing. Other than that, it is never used. It gets oil changes a couple of times a year. The oil that comes out looks like new. My dad brings it home in 50 gallon drums. We have had our 1973 and 1981 Ford tractors since new. They both are running just fine on "used" oil.
Old 01-09-2009, 08:08 PM
hog4u's Avatar
hog4u
hog4u is offline
Talking Everytime the what type of oil thread starts...
It was done in fun. I almost never get "smart" in the forum but the oil questions brings it out.
Sorry if I cause caused any members of PETI undue duress.
People for the Ethical Treatment of Ironheads.
Pat
Quick Reply: what kind of oil in an ironhead
