Batwing Fairing Removal With Pictures
Old 04-09-2006, 11:39 PM
Terry TK's Avatar
Terry TK
Terry TK is offline
Big Kahuna HDF Member
Default Batwing Fairing Removal With Pictures
Most info here was taken from a post by Kess…..I simply added a few pics.
TruBluUltra
Paul
Overview:
There are 7 screws that need to be removed to complete this operation.
Tools Needed:
Torx 27 and the ratchet of your choice. At least a 6” extension is suggested.
Torque Wrench
Use a snap-on magnetic ratchet style screwdriver. You don't drop screws and it's a lot easier to reinstall without stripping out the insert.
Optional: If possible, lift bike slightly so that front tire is suspended off the ground as you will be turning handlebars fully in both directions
Prep: Cover Front Fender and Gas Tank to prevent damage
Use old socks to cover spot lights
Step 1: Locate three Torx Bolts on Top/Front section of fairing (Just under windshield) - Loosen but do not
remove
Step 2: While facing front turn handlebars all the way to the right. Use caution and make certain jiffy stand is fully engaged and in a locked position. Locate Inner Fairing bottom left screw and remove
Step 3: locate Inner Fairing left center screw and loosen but do not remove
Step 4: While facing front turn handlebars all the way to the left. Use caution and make certain jiffy stand is fully engaged and in a locked position. Locate Inner Fairing bottom right screw and remove
Step 5: Locate right center screw and remove
Step 6: Locate left center screw and remove
Step 7: facing the front of the fairing remove top three screws – Suggest you remove center one last. Use caution and pull fairing slightly forward and remove windshield.
Note: Use caution that windshield does not fall
Note: Passing lamps will interfere with removal. Covering the lights with old socks will prevent scratching.
Step 8: Reach behind headlight and remove connection with a side to side motion
Option: At this point I chose to leave the fairing in place, speaker installation did not require removal and the fairing was very stable in this position
Step 9: Use caution and remove fairing moving side to side for clearance – Note position of bottom rubber weather proofing
To install fairing:
Step 1: Re connected head light
Step 2: Position fairing in place using caution that bottom weather proofing is in place and insert top center screw and lightly tighten it
Step 3: Insert Inner Fairing left and right center screws and lightly tighten
Step 4: Insert Inner Fairing bottom left and right screws
Step 5: Install windshield and insert remaining 2 top screws
Step 6: Once you are certain nothing is cross threaded tighten all screws…I used a hand driver to prevent overtorqueing and stripping the screws.
Suggestion: Tighten two Inner Fairing center screws first, then the bottom two and then the top front (7 Total)
What if – There have been many instances where the top three screws that hold the windshield on have been over tightened causing the brass insert to be stripped out. Use caution however if you strip the brass insert simply obtain Part# 16585-96 – The replacement part is threaded on the outside and is an easy repair
Old 08-29-2008, 06:56 PM
08UltraRider's Avatar
08UltraRider
08UltraRider is offline
Default Help removing the fairing
Sorry, didn't mean to highjack this thread.
I'll post a new thread.
Old 11-09-2008, 11:07 AM
CruzN's Avatar
CruzN
CruzN is offline
There is one picture missing off the first thread.
Question: I have an 09 FLHT, I can't find the bolts reference in step three.
"locate Inner Fairing left center screw and loosen but do not remove "
I can only find the one in Step 2 picture with the white arrow.
Is that the one that holds the air deflectors ? Do you have to remove all of them
thank
Old 09-04-2009, 01:18 PM
bcomes's Avatar
bcomes
bcomes is offline
5th Gear
CruzN. I think you're looking for the screw inside the forks (from the riders's side). That's why you have to turn the steering all the way to the left and right. Otherwise you don't have a prayer of seeing these let along getting at them. There is one on each side. When you have a torx driver on it (mine are torx screws) the side of the driver will be touching the inside edge of the fork.
Yes, you have to remove the air deflectors too.
On a side note, I always put a fender cover on and put a small piece of plywood (6-8" wide by about a foot long) in between the forks and then just drop the passing lamps (the bracket and all) down onto that. It makes full removal of the faring much easier.
Brad
Old 09-04-2009, 01:25 PM
FLHXterp's Avatar
FLHXterp
FLHXterp is offline
Brad
Good answer but look at the date of the original question....
Me thinks he may have figured it out by now.
Old 09-04-2009, 05:53 PM
bcomes's Avatar
bcomes
bcomes is offline
5th Gear
Sorry...I've navigated vtwin forum for awhile but just recently returned to hd forum and must have gotten lost. I thought I was reading "new posts"....obviously not!
Old 04-06-2012, 08:57 AM
dirkpit222's Avatar
dirkpit222
dirkpit222 is offline
Thx for the instructional..worked perfect! Tightened the mirrors so hopefully that solves my vibration issue!
Old 05-18-2012, 08:45 AM
jay72's Avatar
jay72
jay72 is offline
Do you have to remove the aux head lamps and turn indicators to remove the front fairing? I just purchased the module that allows the aux lamps to remain on when the bright lights are on. It allows form manual control without regard to the position of the head l;amp switch, bright or dim. An where are the " inner fairing " screws. Also, am I to understand that the screws securing the wind deflectors on either side have to be removed as well? Might as well change the bulbs in the gauges while I'm at it, don't you think?
Old 05-18-2012, 10:53 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
you do not have to remove the aux lamps and turns signals, however, take a cloth of some type and drape over the aux lamps so you don't scratch your fairing when removing it.
you do not have to remove the air-deflectors.
changing bulbs in the small guages is simply replacing the bulbs. the speedo and tach are ultra-tiny LEDS soldered onto the board. Not a job for the faint of heart and better left to the professionals.
there are 3 screws across the windshield on the outer-side of the fairing
there are 2 screws on the inside of the fairing (1 on each side) just above the wind-deflector
there are 2 screws inside the forks in front of the fuel tank. turn your handle bars to the left and right to see them.
Old 07-07-2012, 01:28 PM
Scaredofrain's Avatar
Scaredofrain
Scaredofrain is offline
It might be that in some cases, like mine, there is a need to remove them. No matter what I try I can to get the fairing past the lights.
A very helpful thread on the "how to" bye the way.
bubbas1
09-10-2014 08:49 AM
Gibby13
07-09-2011 05:02 AM
Cheese Head
08-30-2010 12:38 AM
Rhinohd
07-31-2009 11:51 AM
Gregte
07-31-2007 02:51 PM
Quick Reply: Batwing Fairing Removal With Pictures
