Electronic throttle problems on 09 Road King
Old 12-05-2008, 01:05 PM
sybarite's Avatar
sybarite
sybarite is offline
Default Electronic throttle problems on 09 Road King
Just rode an 09 Road King, had the fly-by-wire throttle act up during the ride and remained in idle with no throttle response, despite restarting. Had to let it sit for an hour or so, before it could start up normally with a throttle response.
Another hour into the ride, the problem came back.
Anyone else had better luck with the 09 electronic throttle?
Old 12-05-2008, 01:10 PM
hawg08's Avatar
hawg08
hawg08 is offline
My '08 Street Glide has no problems. I even put new grips on and it still works.
Old 12-05-2008, 01:29 PM
FastHoss's Avatar
FastHoss
FastHoss is offline
Torch it ,collect the ins.money,buy an 05,problem solved
Old 12-05-2008, 01:40 PM
Gutman's Avatar
Gutman
Gutman is offline
This was an issue on early '09's. Pull the codes out of the speedo. Take to a dealer and they will replace the twist grip sensor. We had about 4 of them. No problems on 08's or '09's since.
Old 12-05-2008, 02:46 PM
UltraTheo's Avatar
UltraTheo
UltraTheo is offline
Boy, aren't electronics great? Until they aren't.
Old 12-05-2008, 03:17 PM
gunner11's Avatar
gunner11
gunner11 is offline
Damn those 09's, glad I've got an 08
Old 12-05-2008, 03:43 PM
lasvegasrick's Avatar
lasvegasrick
lasvegasrick is offline
a friend had that problem,check thr wire at the unit under the injectors.his wire had a bad bend at the f b w unit causing it to stop working intermittenly
Old 12-05-2008, 04:27 PM
Solitario's Avatar
Solitario
Solitario is offline
09 rkc no problems at all
Old 12-05-2008, 04:33 PM
PeeTuneYa's Avatar
PeeTuneYa
PeeTuneYa is offline
Sounds classic. Sensor not dialed-in to the 0 to 5V signal is move the sensor to center (sorta find the middle between WOT (wide open throttle) and idle, (or closed throttle say).
Next is your connectors are just not male into female or the wire on one of the connectors is pushed out and just touching are some wire shorts/no signal type sensor defaults as in the sensor is good is it the wire (harness) or connector in between the ECM and the sensor itself, meaning the grip.
Old 12-06-2008, 07:43 AM
Hrlyrider's Avatar
Hrlyrider
Hrlyrider is offline
In English please
Quick Reply: Electronic throttle problems on 09 Road King
