flhx - blacking out turn signal bar - removing bulb sockets????
Old 12-03-2008, 06:06 PM
bobx67's Avatar
bobx67
bobx67 is offline
Default flhx - blacking out turn signal bar - removing bulb sockets????
does anyone know how to remove the bulb sockets/reflectors on the flhx rear turn signals? theres a rubber gasket all the way around and id like to not rip it when i take it apart to powdercoat everything. im not sure if its in the manual, but ive got one ordered.
thanks.
Old 12-03-2008, 06:26 PM
hawg08's Avatar
hawg08
hawg08 is offline
I looked in my service manual and it didn't say anything about removing/replacing the bulb sockets. Maybe you could ask a mechanic at your local dealer if he might have some insight on this. Sorry.
Old 12-03-2008, 06:44 PM
bobx67's Avatar
bobx67
bobx67 is offline
thanks.
im sure someone on here should know. enough people have blacked out their bikes.
Old 12-04-2008, 02:19 PM
bobx67's Avatar
bobx67
bobx67 is offline
anyone???
Old 12-04-2008, 03:19 PM
steveh326's Avatar
steveh326
steveh326 is online now
thanks.
just use a small screwdriver and work your way around them to pry/work them out. I swapped the turnsignal bar on my RG to the SG one, and transferred over the guts from the turnsignals. A little wd40 helps them pop back into place when the time comes.
Old 12-05-2008, 07:24 AM
bobx67's Avatar
bobx67
bobx67 is offline
thanks steveh.
Old 12-05-2008, 09:26 AM
monte64's Avatar
monte64
monte64 is offline
I think you got the answer you wanted, but here is something else you can do, which I did to my bike. "don't mean to high jack your thread here."
I blacked out the saddle bag reflectors and turn signal lenses with some spray tint. It's call "Canopy Spray Tint". You can get some at any hobby store. It is used to tint the plastic bodies on radio control planes and cars.
I used a heat gun to soften the tape which holds the reflectors on the bags and sprayed about 8 very light coats, and I mean very light coat or you will get a ruff finish. At first I thought I went to dark, but at night when the lights hit them they still reflect red. With the turn signals, just remember they still have to be seen.
You can buy some 3M double sided tape at any big name hardware store to put the reflectors back on.
Good Luck. I guess I should stick this in the DIY Section.
HFS
01-16-2018 05:24 PM
drcrazytrain
Touring Parts
07-17-2014 01:15 AM
speedracer
06-08-2013 11:15 AM
Hammerhead Pat
Electrical/Lighting/Alarm
04-17-2013 09:44 AM
brettnbama
05-04-2009 03:06 PM
Quick Reply: flhx - blacking out turn signal bar - removing bulb sockets????
