Connecting cigarette lighter to battery tender pigtail?
Old 11-09-2008, 07:33 AM
sportster2's Avatar
sportster2
sportster2 is offline
Default Connecting cigarette lighter to battery tender pigtail?
Hi all
I was wondering, as I dont know much about electricity, could I charge my cell phone (which runs my navigation software) via the battery tender pigtail. Plus wire from the pigtail goes to the red positive connector on the battery, and the other, minus wire, goes not to the battery, but down to the engine block.
So does that pigtail work both ways, charging the bike battery, or when connected with cigarette lighter, charging the cell phone from the bikes battery?
Or does it make any difference installing different wires alltogether to the cig lighter?
Thanks for any advice
Old 11-09-2008, 08:50 AM
kelton3's Avatar
kelton3
kelton3 is offline
This is what I use.
http://www.powerletproducts.com/prod...ket-cables/319
You can also run a SAE extension cord in between the pigtail and lighter to give you the length to run it up near your speedometer, etc.
Old 11-09-2008, 05:28 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
Should work just fine.... you can find the connector at an auto parts store in the trailer wiring section... it will be an extension cord, so you will actually have 2 connectors if you cut it in half.
Old 11-09-2008, 06:41 PM
Dorkman's Avatar
Dorkman
Dorkman is offline
It will work if you have the gizmo for your cell phone that plugs into a cigarette lighter for charging, using the product mentioned above. It would fraz your phone if you tried to plug it directly into your battery via the battery tender pigtail.
Old 11-10-2008, 01:56 PM
Sail and Ride's Avatar
Sail and Ride
Sail and Ride is offline
It'll work, but you may want to switch and fuse it, too.
Old 11-10-2008, 02:33 PM
cHarley's Avatar
cHarley
cHarley is offline
Just to clarify the original question, yes you can connect a cigarette lighter recepticle to the battery tender pigtail to plug in low power accessories. Many tender pigtails are fused at around 3-5 amps.
But NO, a cigarette lighter draws more amps that the tender pigtail will handle. The typical cigarette lighter has an initial surge current of around 20 amps.
Old 11-10-2008, 04:02 PM
kelton3's Avatar
kelton3
kelton3 is offline
I think most devices like cell phones and gps which comes with a cigarette lighter chargers can be used, they have a build in fuse as well as the tender pigtail. If you are just talking about a regular old cigarette lighter, than yes, it draws too much. right?
Old 11-10-2008, 04:54 PM
cHarley's Avatar
cHarley
cHarley is offline
That's correct.
Old 11-10-2008, 05:59 PM
SpursDarkrider's Avatar
SpursDarkrider
SpursDarkrider is offline
is there enough juice to power one of those small air compressors from walmart into a cigarette lighter recepticle on a pigtail?
Old 11-10-2008, 06:43 PM
schumacher's Avatar
schumacher
schumacher is offline
just hook some jumper cables to yer phone. It'll be fine
bill from tn
01-22-2023 04:22 PM
benningtonr
2014-2023 Touring Models
11
03-04-2017 07:10 PM
deadman77
08-11-2013 07:48 PM
MrC
02-20-2009 07:43 AM
tr6640
04-02-2008 11:23 AM
Quick Reply: Connecting cigarette lighter to battery tender pigtail?
