2004 1200c oil change question..
Old 04-04-2006, 07:43 PM
am7010's Avatar
am7010
am7010 is offline
Default 2004 1200c oil change question..
I am getting ready to change my oil in a 2004, 1200 custom. Can anyone tell me the capacities for the motor oil and the primary. I have no owners manual and the HD shop was out of the sevice manuals. I am changing out both for amsoil. Any help would be apreciated. Thanks
Old 04-04-2006, 08:33 PM
Paulie420's Avatar
Paulie420
Paulie420 is offline
Default RE: 2004 1200c oil change question..
I suggest getting the service manual before attempting any wrenching task on the sporty.
Also, PM me and I can send you a oil change video, performed on a late model sporster.
The oil is very easy to change...
Old 04-04-2006, 11:39 PM
racedvl's Avatar
racedvl
racedvl is offline
ORIGINAL: Paulie420
Good advice! Last fall, I ran over some sort of metal plate in the road and it put a small pin hole in one of the oil lines on the underside of my bike. Mind you I had only had it for 2 weeks at this point. Well having some exp. wrenching on cars, I figured "no problem". Ya. . Before I knew what the cam cover was, I started undoing bolts to get to the oil pump, and all of a sudden I had cams in my lap!! You know that sinking feeling, when you realize you just screwed up. . . . . . . . . .
Old 04-05-2006, 01:25 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Look on ebay for a service manual. Google HD service manuals and you will find a supplier.
Old 04-05-2006, 08:43 AM
am7010's Avatar
am7010
am7010 is offline
Thanks for the advice on the service manual, but I was hopeing someone could just give me the specs on how much oil to put back in the motor and the primary when you change it. If anyone that has a book for a 2004 1200 custom could look, I would be greatful. Thanks
Old 04-05-2006, 06:31 PM
rpoteau's Avatar
rpoteau
rpoteau is offline
AM7010,
I believe the oil capacity is 3.6 quarts
The primary should take exactly 1 quart.
-Use mobil1 v-twin 20w50 to fill the oil tank
-Use RevTech in the primary
Have you seen the scavenger system? Worth checking out.
http://www.roguechopper.com/
Let us know if you have any other questions
Old 04-06-2006, 09:26 PM
am7010's Avatar
am7010
am7010 is offline
I just finished my engine and primary oil change. The primary went fine, the motor oil on the other hand I have a few questions. First the oil drained very slowly from the hose, which I thought was odd so I removed the filter thinking it might speed things up (made the usual mess.) I only got about 2 quarts out of the motor plus what spilled from the filter. I know the oil was a little low due to the famous 2004+ rocket cover leak(now fixed). I replaced the filter and added 3 qt. of oil and now the my oil level looks to be about 3/4 qt. to full. Any thoughts?
Crazy
06-27-2017 07:43 PM
johnb3207
04-26-2013 07:16 AM
DanielBoone
09-25-2007 07:11 PM
acadien
07-25-2007 12:50 PM
07streetbob
12-26-2006 10:05 PM
Quick Reply: 2004 1200c oil change question..
