Electric starter not working
do you have a test light or a DVOM? You wont be able to check without one of the 2. One of the large terminals will have power on it at all times. The small one should get power when you push the pushbutton, and also the other large terminal. If the small terminal doesn't get power when you push the pushbutton, you might have a bad pushbutton or starter relay. If you get power on the small one, but nothing on the 2nd large terminal, then suspect the starter solenoid.
Jump the solenoid small terminal to big wire terminal ( this all takes place after romoving rubber cap on top of solenoid the small terminal usually has a green wire going to it jump to the large terminal to the left of the bike on the solenoid ) This should throw out the starter gear to the clutch gear and the starter should engauge
