Can the baffles be removed from Screamin' Eagle touring mufflers?
Old 10-07-2008, 05:45 PM
DrPlastic's Avatar
DrPlastic
DrPlastic is offline
Default Can the baffles be removed from Screamin' Eagle touring mufflers?
Just looking for options. I plan on keeping the mufflers and installing the V&H Tru duals head pipes soon. I like the look of my mufflers and want to keep them but looking for a bit more bravado!
Thanks
Old 10-07-2008, 06:45 PM
easy-wyatt's Avatar
easy-wyatt
easy-wyatt is offline
Default mine will
i just bought a 97 ultra ..it has screaming eagle slip on,s...they were kinda quiet ...i talked to the local dealer bout them ..baffels and extra holes that kinda stuff ..he said sometime during the production run of ???years the epa started jerkin with em ...so some changes were made ...dont know when mine were purchased and installed but the ones i have the baffels will come out ,,i took off the end cap then i could tell the baffel was loose i drove it halfway out with a wooden dowell then put it back ...might remove it and doctor it up a little later ..just lookin it over now...only had it 3 weeks.
Old 10-07-2008, 06:46 PM
05 Ultra's Avatar
05 Ultra
05 Ultra is offline
Quick answer is no..you can't remove the baffles. But wait till you do the duals. They get alot louder. Some guys change them out cause they're too loud.
Old 10-07-2008, 07:15 PM
C17MSGT's Avatar
C17MSGT
C17MSGT is offline
Default CVO Webdsite
Try this website. They have removed the baffles and Cat.
http://www.cvoharley.com/smf/index.php?topic=27701.0
Maxx
Old 10-07-2008, 07:22 PM
SteveO's Avatar
SteveO
SteveO is offline
No, they are welded in and have converters in each pipe. I drilled out the converters, added very little sound, don't waste your time. Go with the V&H pipes if you can.
Steve
Old 10-07-2008, 07:33 PM
Fatneck 04's Avatar
Fatneck 04
Fatneck 04 is offline
I have some I bought in 2004 and the baffles were tack welded in. I broke the tack welds loose and they came out.
Old 10-07-2008, 08:05 PM
mattman22033's Avatar
mattman22033
mattman22033 is offline
My indy removed the baffles from a pair of SEs. I think he used a blow torch.
Old 10-08-2008, 03:22 PM
DrPlastic's Avatar
DrPlastic
How can I tell if my mufflers have cats in them?
Old 10-08-2008, 03:52 PM
Bigbender's Avatar
Bigbender
Bigbender is offline
I've always wondered what you could do to the stock pipes to make them a little louder. One of my friends took a 1" pipe and punched it back through the center of his '03 SE slip-ons to make the center hole in the baffle bigger. It made a big difference in the noise level.
Old 10-08-2008, 04:56 PM
C17MSGT's Avatar
C17MSGT
C17MSGT is offline
Default Cats
If you have a 09 SE the CAT is in the header. Just remove the slip on and look into the end of the header and you will see a screen.
If it is a earlier bike then the CAT should be in the slip on.
Try this link. It has a picture of the CAT in the header.
http://www.cvoharley.com/smf/index.php?topic=27357.90
Maxx
Quick Reply: Can the baffles be removed from Screamin' Eagle touring mufflers?
