Front End Vibration
Old 09-14-2008, 02:07 PM
LiveLifeLarge's Avatar
LiveLifeLarge
LiveLifeLarge is offline
Default Front End Vibration
When turning at mid to higher speeds, even changing lanes, I feel a rubbing or slight vibration coming from the front end. I wonder if it is the brakes. Any ideas on what it might be. Thanks,
Old 09-14-2008, 03:16 PM
Biggzed's Avatar
Biggzed
Biggzed is offline
Could be a lot of things.
Tires (worn or under/over inflated)
Wheel bearings
Brakes
Forks
Steering head bearings
The list could go on.
Zach
Old 09-14-2008, 06:21 PM
tailgater's Avatar
tailgater
tailgater is offline
Most likely brake pads. The rotors may not be running quite true. Often new pads are all that is needed. The ultra with the C.B. radio has a wiring loom in addition to the standard loom that runs from under the gas tank and under the fairing cap. This loom often rubs the fairing cap when turning. It can be held down with a tie strap but don't pull on it to hard or you will loosen it where it plugs into the radio. If it is the culprit you can feel it in turns and see where it rubs on close inspection.
Old 09-14-2008, 07:15 PM
LiveLifeLarge
Thanks,
I will have it looked at at the next service. Front Brake also squeaks when not engaged so it may be the brakes.
dyna07custom
2014-2023 Touring Models
03-08-2018 07:30 PM
SeniorJeffe
09-20-2016 06:28 AM
fxdx_ftw
General Topics/Tech Tips
12-11-2015 07:09 AM
JohnnyC
EVO
22
06-13-2013 07:21 PM
keith t
10-02-2011 08:09 PM
Quick Reply: Front End Vibration
