HD Chrome Oil Vent Line #33111-02
Old 03-24-2006, 06:28 AM
MDMYMD's Avatar
MDMYMD
MDMYMD is offline
Default HD Chrome Oil Vent Line #33111-02
I am considering this part, but am a little concerned about it replacing a rubber hose. Would this steel line be too rigid causing durability problems, then likelyy breakage? Anyone have this on their bike?
Old 03-24-2006, 08:16 AM
spartns's Avatar
spartns
spartns is offline
Default RE: HD Chrome Oil Vent Line #33111-02
A couple of guys I ride with have it on their bike. There shouldn't be any issue with flexing as the tranny and engine are bolted together. I went with the interface and covered up all of that black.
Old 03-24-2006, 10:31 AM
ricoman's Avatar
ricoman
ricoman is offline
have had one on my 05 RKC for 3000 mi.-no probs. I like the look of a seperate engine and tranny and the chrome line sets it off.
The rear connection is a bear to get a wrench on though.
Old 03-24-2006, 12:00 PM
BladeMan's Avatar
BladeMan
BladeMan is offline
I've put one on my last 3 bikes. The only problem I had was when I was installing it on my second bike an 03 RG. I had a torq wrench and was installing the fitting going into the motor, it twisted off. I had to use an EZ-out to remove it. I took the pieces to the local HD shop and they gave me a new one. I installed the new one, being careful, with no problems. I like the look of the chrome line better than a chrome cover. I installed one on my SG with no problems.
Old 03-24-2006, 12:14 PM
lil_gmac2's Avatar
lil_gmac2
lil_gmac2 is offline
You should have any problem by installing this part.
Old 03-24-2006, 12:31 PM
Thundercloud's Avatar
Thundercloud
Thundercloud is offline
I have one on my 05 Road Glide since new and after 9200 miles, no issues at all.
Old 03-24-2006, 03:35 PM
blueknight's Avatar
blueknight
blueknight is offline
I put one on mine, no problems, just thread lines by finger tight only, before snugging up withwrench. Thereby not crossing theads and breaking off. Looks good and should definitely out last rubber line. Rubber dries out, cracks, gets hard and eventually leaks. Put something pretty on it to last.
Old 03-24-2006, 04:16 PM
Twinuts's Avatar
Twinuts
Twinuts is offline
The fitting at the oil filler spout is a compression fitting with a ferrule wich makes it a rigid connection. But on the engine end it is a captured rubber washer of sorts and is not rigid any way. I've installed two of them on my bikes, one has about 30K miles with no problems. The only thing I noticed between the old one and the new one is the bending is better one the old one and it looks straighter. The newer one dosen't look right and if you try to bend the tubing you'll crack the chrome. Oh well it must be progress.
Old 03-24-2006, 10:18 PM
Neckball's Avatar
Neckball
Neckball is offline
Working on an alternative. Waiting on the proper size fitting for the engine end of the hose so I don't have to use the adapter bushing. Should be in Tuesday.
[IMG]local://upfiles/1975/3AF52A640177459583E7A46F105473ED.jpg[/IMG]
Old 03-24-2006, 10:37 PM
Barebackjack's Avatar
Barebackjack
Barebackjack is offline
I have it on my 04 FLHRC. 18,000 miles and no problems.
Quick Reply: HD Chrome Oil Vent Line #33111-02
