generator removal ?
Old 09-02-2008, 01:41 PM
DAILYRDR's Avatar
DAILYRDR
DAILYRDR is offline
Default generator removal ?
Helpin' a buddy of mine out and trying to remove the gen. I'm a auto tech. just not familliar with the shovel's. Got the case off just not the armature. Look's like housing is stuck to case with silicone. Just not sure and didn't want to dig out prybar to try.Any help out there?
Old 09-02-2008, 01:49 PM
FilthyLucre's Avatar
FilthyLucre
FilthyLucre is offline
On the 66 to 69 Generator shovel the generator is held on by two bolts on the cam cover side,(right) Once remove and wires disconected generator should come off as a unit.
Old 09-02-2008, 02:21 PM
DAILYRDR's Avatar
DAILYRDR
DAILYRDR is offline
So i need to remove the cam cover to acess them?
Old 09-02-2008, 02:34 PM
FilthyLucre
No, it is two 7/16 bolts on the outside of the cover. Should be easy to see, the rest of the cover hardware are screws.
Old 09-02-2008, 02:36 PM
Rodney's Avatar
Rodney
Rodney is offline
no!
the bolts are on the right side going though the case to the generator housing.
Old 09-02-2008, 02:44 PM
DAILYRDR's Avatar
DAILYRDR
DAILYRDR is offline
Ok, found 2 allen head bolt's and removed them.but i guess the silicon's got it stuck,so guess try seperating them with screwdriver.
Old 09-02-2008, 02:56 PM
Rodney's Avatar
Rodney
Rodney is offline
I'd use a stiff putty knife or scraper and gently tap in between the 2 surfaces.
Old 09-02-2008, 03:06 PM
DAILYRDR's Avatar
DAILYRDR
DAILYRDR is offline
Well still tryin' guess it'll pop loose sooner or later. Thank's guy's.
Old 09-02-2008, 03:16 PM
Rodney's Avatar
Rodney
Rodney is offline
you might soak the area down with gasket removing spray and let soak for an hour or so..
or bolt the generator housing back on the bearing housing, that should give you some thing more to grab a hold of..
Old 09-02-2008, 03:19 PM
DAILYRDR's Avatar
DAILYRDR
DAILYRDR is offline
I'll try that also.
Quick Reply: generator removal ?
