Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Trying to remove fuel inlet fitting!!!
Old 09-02-2008, 08:15 AM
the Trizz's Avatar
the Trizz
the Trizz is offline
4th Gear
Default Trying to remove fuel inlet fitting!!!
I just got my 93 Sporty and have been doing some upkeep work. I'm trying to replace a cracked fuel inlet fitting and cannot seem to remove the brass fitting that goes into the carb.
It will turn freely when I grip it with plyers, but makes no effort to come out of the hole!
The glue was left over from the old inlet.
Any ideas?
Thank you,
Trizz
Old 09-03-2008, 09:41 PM
hogdoctor's Avatar
hogdoctor
hogdoctor is offline
Easy. Insert the largest drill bit that will fit in the hole. This will keep the brass tube from collapsing and cracking off. Now get on it with a vise-grip, clamp down hard and rotate/twist the fitting out. set the new fitting pointing in the correct direction and squeeze it into the casting. I use a monster set of channel lock pliers to push it in.
Hogdoctor
Old 09-04-2008, 07:23 PM
the Trizz's Avatar
the Trizz
4th Gear
Default Fuel inlet
Thanks for the help! I should have waited to get the monster channel locks... a ball peen hammer isn't quite as easy on that plastic!!!
Oh well, there goes 15 more bucks, live and learn to be patient!
Thanks again... there will be more questions to follow, like will a CV carb off a 95 1200 sportster fit my 93???
Guess we'll know when it comes in!
T
Old 09-05-2008, 08:07 PM
hogdoctor's Avatar
hogdoctor
Yes, it will fit. Same same. uncork your idle fuel adj. screw and check your jet numbers before installing it, in case you have to mess with the tuning...
Hogdoctor
Old 09-09-2008, 11:40 PM
the Trizz's Avatar
the Trizz
4th Gear
Well, I got them changed out, put on new gaskets and all! Now it just sits there and cranks... I'm lost as to what to do now... UGH!!!
Old 09-10-2008, 08:00 AM
hogdoctor's Avatar
hogdoctor
fuel flowing to the carb? accelerator pump squirts?
spark at the plugs?
compression in the cylinders?
something is missing...
Hogdoctor
Old 09-11-2008, 01:34 AM
the Trizz's Avatar
the Trizz
4th Gear
Default Fuel
I know that the motor worked prior to replacing the carb, so that pretty much rules out spark to the plugs, and compression. I can also hear the air being sucked in as the pistons move.
The replacement carb may be the problem, with the air intake part off I don't see any gas being squirted into the chamber. I did see on Youtube that this is a fairly easy carb to disassemble and clean. Maybe I should try that?
I was told by the seller that at least 3 mechanics said that the old carb should be replaced, even though the bike seemed to run well with it! It had a cracked fuel inlet, which of course leaked gas, but I can see nothing else wrong with it!
Thanks so much for your help, mucho appreciated!
T
Old 09-11-2008, 09:14 AM
hogdoctor's Avatar
hogdoctor
So put a new fuel inlet on the old carb and put it back on.
Then you can tear this carb apart and figure out why fuel isn't flowing properly.
Hogdoctor
Old 09-14-2008, 02:12 PM
the Trizz's Avatar
the Trizz
4th Gear
That kind of insight is why you're the Dr! That's exactly what I'm gonna do next! Now I've gotta figure out why the tail light isn't working. I'm off to put the bike up on a lift and drop the rear wheel... yee haw!
Old 09-20-2008, 06:26 PM
bigoscycles's Avatar
bigoscycles
bigoscycles is offline
Keep us posted on your progress.
green loctite
Carburetor Related
10-09-2015 10:40 PM
Gary Crum
Carburetor Related
05-26-2014 10:42 PM
shovelheadgreg
Exhaust System Topics
11-02-2010 01:37 PM
wideglidedan
06-14-2006 11:10 PM
Tim
04-10-2006 09:31 PM
Quick Reply: Trying to remove fuel inlet fitting!!!
