fuse box sportster
Old 08-22-2008, 10:33 AM
Menfis's Avatar
Menfis
Menfis is offline
Stage I
Default fuse box sportster
Hello,
Can sombody tell me were i can find the fuse box for my 2000 sportster?
Thank you very much.
Glen Schuurbiers.
Old 08-22-2008, 10:57 AM
harleychicknj's Avatar
harleychicknj
harleychicknj is offline
Isn't it on the left side next to the battery behind the triangle plate?
Old 07-05-2009, 08:41 AM
dro5959's Avatar
dro5959
dro5959 is offline
Stage III
Default Sportster Fuse Box
Can anyone help me locate the fuse Box on my 2000 1200S Sportster. The Manual tells me its under the seat but I can't find it?
Help !
Old 07-05-2009, 10:45 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Thats where the ignition module is.
xFreebirdx's Avatar
xFreebirdx
My 96 has 4 fuses, 50 amp, starter relay, etc. under the seat. It is mounted to the cross member by the back of the seat.
My fuses are obvious, but to change my starter relay I have to drill 2 rivets and slide the whole thing up and out. I replaced the rivets with mill tips for easier access.
Old 06-16-2020, 10:16 PM
Dutch W's Avatar
Dutch W
Dutch W is offline
Stage II
Default Fise box loc
Help !
ation
On my 04 it 1200 sporty custom it is located to the right of battery under a triangular- ish panel.
Old 06-17-2020, 03:42 AM
Andy from Sandy's Avatar
Andy from Sandy
Andy from Sandy is offline
Received 3,724 Likes on 2,394 Posts
You should be able to download the owner's manual for your bike from
https://www.harley-davidson.com/shop...-owners-manual
Old 06-18-2020, 12:16 PM
grbrown's Avatar
grbrown
grbrown is offline
Talking
Indeed, although that wasn't possible 12 years ago....
The following 2 users liked this post by grbrown:
Dan89FLSTC (06-20-2020), shanneba (06-20-2020)
Old 01-13-2023, 05:52 AM
captcorvette's Avatar
captcorvette
captcorvette is offline
OK I must be thick as a stump. For the life of me I cannot find the fuse box on my 1996 Sportster 883 bone stock ride. I can and have found, the ignition module, the turn signal module and various connectors but nothing that has any fuses in it. Have pulled everything out from this under seat and side triangle cover that I can find. But anything that has fuses in it escapes me. Have looked as closely as possible to the relays but still no fuse box. This bike, the battery was hooked up backwards and the cables to the battery were reversed. The shop that was supposed to do a "service" returned the bike as they could not get it to start. But according to one of the lads in the shop they put charger on the bike when they hooked up the battery backwards. Then they gave up and returned the bike to me. Removed all that. Purchased new battery and installed correctly. Key on and have lights run signals, starter but no start. Have even checked the coil wires by removing and checking for continuity. All good. Just not getting spark to the plugs. Guidance? Please. Don't want to just start throwing parts at the bike until stumbling on a solution.
Last edited by captcorvette; 01-13-2023 at 05:55 AM. Reason: Stupidity, lousy proof reading and various omissions.
Old 01-13-2023, 06:04 AM
Andy from Sandy
Does it have fuses or circuit breakers?
THis will get you a pdf download of the wiring diagrams and more - https://serviceinfo.harley-davidson....t/view?id=5520
Quick Reply: fuse box sportster
