changing oil on street bob
Old 08-13-2008, 05:16 PM
francis's Avatar
francis
francis is offline
Default changing oil on street bob
Any of you guys tell me why im finding it so hard to get the oil out of my street bob. Engin hot tip it on its side still have to use pump to get old oil out, no owners manual with the bike, is there something im missing? Thanks.
Old 08-14-2008, 01:48 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
You are missing a service manual. Get one for $50 from your dealer. well worth the investment. Your engine drain plug is the one on the left side that faces straight sideways down where the jiffy is. If the oil won't drain out of there then it is not returning to the tank and that is a different issue.
Old 08-15-2008, 04:48 PM
francis's Avatar
francis
francis is offline
Thumbs up francis
Thanks mate. over here in UK harley take the **** with there prices, £58 for a servise manual, im not poor im proud, thanks for your help, I took drain plug out but the oil would not come out, I put a suction pump to it and got the oil out that way. I thought Harley in there infinate wisdom had put a release valve on the engin some where. will get servise manual of ebay. Thanks
Old 08-15-2008, 04:51 PM
Bluesssman's Avatar
Bluesssman
Bluesssman is offline
When you refer to the drain plug, your are not referring to any plug on the engine are you?
Old 08-15-2008, 05:02 PM
rockon's Avatar
rockon
rockon is offline
When you drained it did you also remove the oil filter? That should make it shotgun like a beer.
Old 08-16-2008, 02:25 PM
francis's Avatar
francis
francis is offline
I always change engin and gearbox oil at same time, both drain plugs were off .
Old 08-16-2008, 02:29 PM
francis's Avatar
francis
francis is offline
No I did not have oil filter off at the time, good suggestion will make sure I will take oil filter off next time, Thanks for your help.
Crash75
01-07-2013 06:21 AM
harleyguy53
08-18-2012 10:43 AM
writer1973
06-02-2011 09:08 AM
sprocketbos1
12-22-2010 07:34 PM
harper764
06-03-2008 12:50 PM
Quick Reply: changing oil on street bob
