HELP!! Installing forward controls on 2003 FXDL with mids.HELP!!
Old 08-10-2008, 05:04 PM
muleman's Avatar
muleman
muleman is offline
Default HELP!! Installing forward controls on 2003 FXDL with mids.HELP!!
So i just got a set of jaybrake forward controls for my 2003 fxdl it has mids from the factory.. question is what am i going to have to buy to install, i know a shift rod 13in to 15 in hole to hole... but the brake side has a brake reservior on the forward control and i have one on the bike.. how will i deal with this... any help would help. thanks.
Old 08-10-2008, 05:42 PM
benwiggin2's Avatar
benwiggin2
benwiggin2 is offline
So, it came with a brake resevoir, but didn't come with a shift rod? Also, most important question, didn't come with instructions???
Old 08-10-2008, 05:50 PM
muleman's Avatar
muleman
muleman is offline
they are used no instructions... they came off a dyna that already had forwards on it, so they used the shift rod on the orginals.. the shift rod is no big deal... jsut the brake set up any help....
Old 08-10-2008, 06:40 PM
8541hog's Avatar
8541hog
8541hog is offline
You will need to buy a universal brake line, I just did this on my wide glide, you can reuse the sending unit switch, but pretty much everything else will have to be new
It is not difficult, the hardest part was finding a shop that stocked what I needed, you will need crush washers for the banjo bolts, you may need to extend the wires to the new location of the sending unit, and you will need clamps for the new brake line
PM me if you need details
Old 08-10-2008, 08:29 PM
muleman's Avatar
muleman
muleman is offline
yea i would really like the instructions.. can you shoot them to me..
Old 08-10-2008, 09:00 PM
8541hog's Avatar
8541hog
8541hog is offline
Well, I don't have any instructions, I had to figure it out as I went, but I am willing to answer any questions to help. I do have a linkage rod that might work for you but you will need the heim joints as well as the bolts. The rod I got with mine was too short. What do you have so far? Have you started taking anything apart yet or checking fit?
Old 08-10-2008, 10:49 PM
muleman's Avatar
muleman
muleman is offline
all i got is the forward controls and the stock stuff on the mid controls... i know i need a shifter rod.... what else.
Old 08-11-2008, 05:33 AM
8541hog's Avatar
8541hog
8541hog is offline
I think I have suggested everything you will need in the way of parts, do you have a service manual? Do you know how to bleed brakes? Does your bike use Dot 5 or DOT 4?
Old 08-11-2008, 10:34 AM
muleman's Avatar
muleman
muleman is offline
if the forward controls have a brake res. on it and the stock is still on the bike do you just block off the stock brake res. or what?? and use the one on the forwards??
Old 08-11-2008, 10:47 AM
8541hog's Avatar
8541hog
8541hog is offline
Yes, you will have to remove all stock brake parts except the caliper, and sending unit switch. You will reuse the switch and caliper. But everything else is basically going to be new.
BartMan88
04-18-2016 04:53 PM
padge1984
10-11-2014 02:38 PM
slamtry
12-11-2011 08:00 PM
salebrity
03-31-2011 11:01 AM
BluBob
05-06-2008 11:49 AM
Quick Reply: HELP!! Installing forward controls on 2003 FXDL with mids.HELP!!
