Using ATF in a primary?
Old 08-08-2008, 03:45 PM
TIPN8R's Avatar
TIPN8R
TIPN8R is offline
MODERATOR
Default Using ATF in a primary?
Just read in the directions on my Rivera Primo Pro Clutch PC1200A and it recommends to use Dexron III.
I've been using Rev Tech Primary lube, been working fine, anyone else using anything other than trans fluid?
Pro's and Cons?
Thanks!
Old 08-08-2008, 03:46 PM
Bluesssman's Avatar
Bluesssman
Bluesssman is offline
I think I would use the manufactures recommended fluid and not worry about it.
Old 08-09-2008, 05:18 PM
miacycles's Avatar
miacycles
miacycles is offline
Use the ATF fluid your plates will last longer. If you think about it the primary and an automatic tranny have the same things in them, bearings, friction plates/bands, and chains in front wheel drive cars.
Old 08-09-2008, 08:03 PM
liltrk's Avatar
liltrk
liltrk is offline
Amsoil synthetic ATF here. Some like synthetic trick shift.
Old 08-10-2008, 08:13 AM
Dalton's Avatar
Dalton
Dalton is offline
Put the Pro Clutch in almost 15000 miles ago and have not had any issues running the ATF. I do not use an expensive oil either. If there would have been issues, I am sure by know I would have run into them.
Think about it, all automotive transmissions have clutch paks and they survive just fine on ATF. The oil in the primary is primarily used to control heat with a side benenfit of lubrication.
mykee
06-14-2012 02:48 PM
EXAMMO
Oil Archive (no new posts)
06-20-2010 02:22 AM
Black Bart
25
07-24-2007 08:19 AM
but Ill try 2 try
03-24-2007 01:28 AM
98_FXSTC
05-19-2006 11:34 PM
Quick Reply: Using ATF in a primary?
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
