Leak from stator wire grommet
Old 08-02-2008, 10:26 PM
TheBagger's Avatar
TheBagger
TheBagger is offline
Default Leak from stator wire grommet
My '00 Road King has a small oil leak around the grommet for the stator wires, front left of engine.&nbsp\\; Any ideas on how to stop this leak?&nbsp\\; I think that that grommet is part of the wire assembly but I'm not sure.
Old 08-02-2008, 11:31 PM
TheBagger's Avatar
TheBagger
Default RE: Leak from stator wire grommet
found the answer to this but cant post it....@#$$^ forum.
TheBagger's Avatar
TheBagger
After some research I see that this grommet is part of the stator wire so it cant be replaced by itself.
Old 08-02-2008, 11:33 PM
TheBagger's Avatar
TheBagger
Looks like I will have to remove it with the stator to stop this leak.
Old 08-02-2008, 11:34 PM
TheBagger's Avatar
TheBagger
Also found out that because of oil leaking on these wires the plug connection can short out under the right footboard area. There is a service bulletin (M-1107 dated 2/20/01) to relocate this plug so oil cant seep into it.
TheBagger's Avatar
TheBagger
This looks like another good winter project to me...
Old 08-02-2008, 11:37 PM
TheBagger's Avatar
TheBagger
Thanks for all your help TheBagger...can I buy you a beer?
(Talking to myself pay no attention.)
Old 08-03-2008, 06:10 AM
Jinks's Avatar
Jinks
Jinks is offline
Open the primary &amp\\; seal the hole around the plug with silicone sealant.&nbsp\\; Or, do away with the plugs all together.&nbsp\\; Hard wire the regulator to the stator &amp\\; fill the hole with sealant.&nbsp\\; I've done both, &amp\\; hardwiring eliminates shorting in the plug.
Old 08-03-2008, 10:56 AM
bagman1's Avatar
bagman1
bagman1 is offline
if you seal the grommet make sure you use an rtv sealant or it will leak, and wait 24 hrs for it to cure otherwise it will leak. The best sealant out there is called the right stuff.
Runamuk13
05-04-2021 06:05 PM
semiret
04-15-2013 04:08 PM
aussiesport
01-13-2012 09:04 AM
jfm5
07-09-2009 03:50 PM
Gem99Ultra
03-27-2008 08:09 AM
Quick Reply: Leak from stator wire grommet
