backfire in intake
Old 07-25-2008, 04:05 AM
redned's Avatar
redned
redned is offline
Stage IV
Default backfire in intake
2001 springer st, hard to start and is backfiring at idle,no codes will come up .but a twin scan 2 shows the timing to be different on one cylinder at idle and low rpm.plugs,cables,coil are good three days of this is getting old help...........,
Old 07-25-2008, 01:07 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Default RE: backfire in intake
Check intake for leaks, do a compression test to see if intake valves are leaking
Old 07-25-2008, 10:03 PM
redned's Avatar
redned
redned is offline
Stage IV
I checked for a air leak around the intake but I will do a leakdown test on it, this bike has 15000 mile on it ,I can"t understand why there is 10 degrees different in timing&nbsp\\; between cylinders,.
Old 07-26-2008, 07:41 AM
Doc 1's Avatar
Doc 1
Doc 1 is offline
It's common to see AFR and timing to jump all over the place at idle due to the MAP pulses. The timing and AFR&nbsp\\; should mellow out off idle though.
Old 08-02-2008, 11:17 PM
redned's Avatar
redned
redned is offline
Stage IV
today I unpluged the MAP sensor and the bike ran good, as soon as iI plug it back in it starts backfiring again. I have another MAP that I put in the throttle body and put the wires on the other one and let it hang ang it runs good and the light dont stay on ,what do I do next.
Old 08-02-2008, 11:51 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
I would check the IAC steps now but you need a digital tech or a SERT in data mode to see what the steps are.
&nbsp\\;
Old 08-08-2008, 09:56 PM
redned's Avatar
redned
redned is offline
Stage IV
After all the checking the customer said the ecm had a hd download in it but with a twin scan 2 it didnt show that,I put a new ecm on the bike and now it runs good.. thinks for the input
madodge68
10-30-2018 11:19 AM
JonathanSShaw21
Ironhead
07-18-2016 09:29 PM
carlgrover
Ironhead
11-02-2015 12:23 PM
Spud17
05-25-2012 06:09 PM
asuperheat
08-29-2006 10:13 PM
Quick Reply: backfire in intake
