Front wheel wobble
Old 07-19-2008, 08:55 PM
tlr's Avatar
tlr
tlr is offline
Default Front wheel wobble
Here is the issue.&nbsp\\; When slowing down to come to a light (30mph or so) and I let go of the bars, the bars and front wheel have a very definite wobble.&nbsp\\; Once&nbsp\\;I grab&nbsp\\;the bars it stops.&nbsp\\; It seems that it is there also during very slow manuevers.&nbsp\\; Any ideas.&nbsp\\; Ride is an 08 Road Glide with about 1500 miles.&nbsp\\; Thanks all in advance.&nbsp\\;
Old 07-19-2008, 09:01 PM
Bluesssman's Avatar
Bluesssman
Bluesssman is offline
Default RE: Front wheel wobble
Steering head bearings adjustment? Front tire pressure?
Old 07-19-2008, 09:03 PM
Big Cholla's Avatar
Big Cholla
Big Cholla is offline
Clean the front brake discs and pads with brake cleaner.&nbsp\\; Should take care of the problem.&nbsp\\; ...&nbsp\\;&nbsp\\; BC
Old 07-20-2008, 11:09 AM
GGC's Avatar
GGC
GGC is offline
Keep hands on bars?!!problem fixed.
Old 07-20-2008, 11:21 AM
iambill's Avatar
iambill
iambill is offline
I had the same prob with my 06 herritage. same speed too thought it was too much weight on the back especially when the wife was riding with me ( no pun intended ).
I tightened up the steering a bit, which helped a little. But it never went away.
sry couldnt help
&nbsp\\;
Old 07-20-2008, 12:51 PM
cfmii11's Avatar
cfmii11
cfmii11 is offline
+1 on the neck bearings, it just happened to a friend of mine with his 07 Heritage.
Charlie
Old 07-20-2008, 01:38 PM
vibr8ir's Avatar
vibr8ir
vibr8ir is offline
Check and see if you tires traveling in the right direction.(arrows). Maybe put on wrong??
Old 07-20-2008, 02:38 PM
tailgater's Avatar
tailgater
tailgater is offline
One front rotor not running quite true. Rotor touches brake pad at one point is tire rotation. This will cause the no hands tire wobble at slow speed. It will also cause the front tire to cup. Come to a slow speed stop useing only the front brake. If you feel a pulsing then this is the reason.
[align=left] [/align]
Old 07-20-2008, 02:42 PM
nedster's Avatar
nedster
nedster is offline
My 08 roadglide has the same wobble since day 1, I had the front wheel re -balanced, did not cure it. Then I was wondering if it had something to do with the way the motor mounts are installed on the 08's.
Old 07-20-2008, 02:50 PM
PRrdglide's Avatar
PRrdglide
PRrdglide is offline
I have had 3 Harley's all of them have done it 02 heritage. 05 low rider ,07 road glide
Quick Reply: Front wheel wobble
