Sponsored by: Jekill and Hyde
head gasket leak (cost of repair)
Old 07-04-2008, 08:29 PM
grippper's Avatar
grippper
grippper is offline
1st Gear
Default head gasket leak (cost of repair)
harley dealer told me you cant replace the head gasket without replacing the base gasket. is this true.anyone know what the cost of a head gasket repair from the dealer goes for&nbsp\\; and how long does it take them to do it.
&nbsp\\;
Old 07-08-2008, 10:36 AM
Javieret's Avatar
Javieret
Javieret is offline
Default RE: head gasket leak (cost of repair)
I don't see why you can't replace the head gaskets without replacing the base gasket. When my bike was in guaranty, the dealer replaced my head gasket because it was leaking and just that gasket.
Javi
Old 07-08-2008, 06:53 PM
Dalton's Avatar
Dalton
Dalton is offline
Yep, can be done.&nbsp\\; The gasket is about $25 and you could do it yourself in about 4-6 hours.&nbsp\\; I dont know what flat rate is at the dealer but should be no more than 4 hours I am thinking
Old 07-08-2008, 11:14 PM
TXCHOP's Avatar
TXCHOP
TXCHOP is offline
Is this an EVO or twin cam? By base gasket i assume evo as the twinkies had orings. If EVO, i would change out head and base.
Old 07-10-2008, 10:48 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
If it is a twin cam I don't think any dealer is going to chance just changing the head gasket without changing the two orings at the base.&nbsp\\; If they leak they end up doing the job a second time.&nbsp\\; If you are doing it yourself you can pull the head carefully not to disturb the base oring.&nbsp\\; I know some reputable techs will say that if you have over 12,000 miles on the bike the oring should be changed and if lower than 12,000 miles it should be ok.&nbsp\\; It really does not take much longer to pull the cylinder and the piston can be left in the cylinder so the rings do not need to messed with or the cylinder does not need to be honed.&nbsp\\; Depending on model the biggest pain is removing the exhuast system (on a bagger anyway)&nbsp\\; the job is actually pretty easy if you have a service manual.
cvaria
Engine Mechanical Topics
08-23-2018 02:00 PM
hdHuck
EVO
08-16-2014 06:20 AM
Fl Jimbo 05
08-11-2011 10:11 PM
rivercityslim
EVO
11-16-2009 02:50 PM
bigstevex4
06-04-2008 03:11 PM
Quick Reply: head gasket leak (cost of repair)
