Idle speed...
Old 07-03-2008, 12:54 PM
SD Night Train's Avatar
SD Night Train
SD Night Train is offline
Default Idle speed...
is it just me or do the 07 &amp\\; 08's idle fast?&nbsp\\; Is there a way to lower the idle speed?
Old 07-03-2008, 07:10 PM
Blk and Chrome's Avatar
Blk and Chrome
Blk and Chrome is offline
Default RE: Idle speed...
not sure if can....mine is only fast after sitting and cooled down, but comes down quick. they won't idle like a carb model
Old 07-03-2008, 07:26 PM
mjmangus's Avatar
mjmangus
mjmangus is offline
ORIGINAL: SD Night Train
is it just me or do the 07 &amp\\;\\\\\\; 08's idle fast?&nbsp\\;\\\\\\; Is there a way to lower the idle speed?
No it's not you, they do idle fast to keep the oil pressure up.&nbsp\\;
Old 07-03-2008, 08:25 PM
YTHOG's Avatar
YTHOG
YTHOG is offline
&nbsp\\;
DO NOT AND I REPEAT, DO NOT try to lower your idle on the 07 - 08's. They have to idle at approx 1,000 to 1,200 rpm's.&nbsp\\; The oil pumps need the idle speed to keep the oil pressure up.&nbsp\\;
Old 07-04-2008, 04:13 AM
djcustom1's Avatar
djcustom1
djcustom1 is offline
You can lower the idel with sert BUT IF YOU DO YOU WILL BURN YOUR MOTOR UP. thay are set at 1000 to 1200 to keep oil presure up so you starve the top end off oil.
Old 07-04-2008, 08:05 AM
srm148's Avatar
srm148
srm148 is offline
Trust them on this, I have an 04 Train, carbureted, and mine was idling around 800 or so. HD told me to bump it up to at least 1050, to help the oil pump. Glad I caught that in time!!
Old 07-04-2008, 10:28 AM
Mr. Lucky's Avatar
Mr. Lucky
Mr. Lucky is offline
ORIGINAL: YTHOG
My 08 Softail service manual (pg 1-6) specs engine idle speed at 950-1050 RPM.
Old 07-04-2008, 01:18 PM
Lamo70's Avatar
Lamo70
Lamo70 is offline
there's no "potato-potato-potato" idle sound on the fuel injected bikes. too bad for us.
ultraclassic53
05-07-2015 07:52 PM
mhenry
03-31-2012 06:01 PM
tjbitt
10-06-2011 07:03 AM
wildeano
11-08-2008 09:26 PM
Bagged Out
10-31-2008 11:45 AM
Quick Reply: Idle speed...
