brake job?
Old 06-29-2008, 10:38 PM
krazedstang's Avatar
krazedstang
krazedstang is offline
Default brake job?
hey guys, i noticed today that my brakes are gettin down to the last bit, and was wondering just how hard it is to do a brake job on my 02 XL883C? i mean ive done plenty of brake jobs on cars, but not to sure on a motorcycle, thanks
Old 06-29-2008, 10:41 PM
anubisss's Avatar
anubisss
anubisss is offline
Default RE: brake job?
Easy.&nbsp\\; Get a set of pads for the front and back, some brake cleaner and a bottle of fluid if you think you'll need it.&nbsp\\; Also get a service manual.&nbsp\\; Much simpler than a car. &nbsp\\;
Old 06-30-2008, 12:25 AM
RKKY's Avatar
RKKY
RKKY is offline
Easy.&nbsp\\;
&nbsp\\; +1
&nbsp\\;
Not only much simpler than a car, Sporty brake pads are the easiest of the H-D's. You shouldn't have any problems at all.
Old 06-30-2008, 12:33 AM
SportyPig's Avatar
SportyPig
SportyPig is offline
30 minute job, including a beer break between front and rear.
Old 06-30-2008, 12:44 AM
stlboarder's Avatar
stlboarder
stlboarder is offline
Well ****... if their easier than a car then I should be able to do them in my sleep and still have time for a beer break.
Old 06-30-2008, 04:30 AM
SpursDarkrider's Avatar
SpursDarkrider
SpursDarkrider is offline
Use the aftermarket pads instead of the crappy HD ones
Old 06-30-2008, 06:17 AM
cHarley's Avatar
cHarley
cHarley is offline
ORIGINAL: SpursDarkrider
+1 Lyndall pads are highly recommended, either the Z-Plus or Gold. Better stopping, longer lasting and NO Brake Dust.
http://www.lyndallracingbrakes.com/apps.htm
Old 06-30-2008, 06:20 AM
pscheval's Avatar
pscheval
pscheval is offline
get the service manual... it'll make your life easier
Old 06-30-2008, 05:31 PM
krazedstang
well then, it seems like i will be doing a brake job on my sporty very soon, thanks guys
Old 07-01-2008, 05:49 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
be sure to get high temp brake pad grease for the back of the pads, to remove the caliper pegs you will need a 5mm rachet i belive, i know it is a 13point but i can not recall what one... if you can not figure it out, PM me and i will check in my shop for the right one for you... AHHH i can not belive i can not recall what size rachet that is!
Manish_Hawg
07-18-2008 08:23 PM
cst010
07-02-2008 08:07 AM
Harleyridin77
07-02-2008 06:07 AM
Graywolf584
Custom Models
06-27-2008 07:07 PM
deadman77
06-18-2008 08:50 PM
Quick Reply: brake job?
