1967 SHOVEL IN SANTEE SOFTAIL FRAME
Old 06-29-2008, 06:23 PM
Xmoto's Avatar
Xmoto
Xmoto is offline
Stage II
Default 1967 SHOVEL IN SANTEE SOFTAIL FRAME
I HAVE A CHANCE TO BUY A 1967 SHOVEL ENGINE. I NEED TO KNOW IF IT WILL GO IN TO A SANTEE D&amp\\;D SOFTAIL FRAME. AM I GONG TO HAVE A PROBLEM PUTTING IN A 5 OR 6 SPEED TRANS. WILL I HAVE INNER PRIMARY PROBLEMS WITH THE ENGINE AND THE LATER STYLE TRANS. I AM SUPPOSED TO BUY THE ENGINE THIS THRUSDAY. NEED HELP.
Old 07-02-2008, 07:55 PM
stroker93's Avatar
stroker93
stroker93 is offline
Default RE: 1967 SHOVEL IN SANTEE SOFTAIL FRAME
I have a 55 pan motor in a HD heritage frame with a softail 5 speed in it..I had a few issues with the pipes and I run an open BDL belt set up and have a offset front pulley spacer to make the belt line up....I also have a Santee D&amp\\;D 180 frame with an Evo in it...Its got the offset built into it so you can run a fat tire,,,this might cause some extra alignment issues or it might work in your favor...I do believe that you will have to run an open belt without your primaries to make it work.
Dave
Old 07-04-2008, 09:23 AM
traveler's Avatar
traveler
traveler is offline
hard to say, as some frames are meant for "cone head motors".&nbsp\\; A 1967 generation shovel has the generator case like than pan's and earlier, and might not work.&nbsp\\; I would talk to snatee, and find out before you start doing any work.&nbsp\\; Hope it works out for you!&nbsp\\; If you have the entire 1967 drivetrain, that is worth some $$$$$.&nbsp\\; VERY desireable, and would hate to see it get broken up and pieced out.&nbsp\\; If it were mine, I would get a Harley early frame and have it hardtailed, by that's just me.[&:]
&nbsp\\;
~Joe
&nbsp\\;
Alex E
11-08-2016 06:08 PM
nellis003
EVO
02-11-2016 03:54 PM
HogglyWoggly
EVO
11-28-2012 11:27 AM
what_about_bob
09-28-2009 11:20 AM
drumbumm
11-26-2006 09:41 AM
Quick Reply: 1967 SHOVEL IN SANTEE SOFTAIL FRAME
