broken antenna
Old 06-24-2008, 09:55 PM
steve marshall's Avatar
steve marshall
steve marshall is offline
Default broken antenna
My wife hit my baby with her car and broke the left antenna clean off at the base, no threads left.&nbsp\\; does harley make a replacement or does anyone have any other ideas?
Old 06-24-2008, 10:02 PM
Big Blue Bike's Avatar
Big Blue Bike
Big Blue Bike is offline
Default RE: broken antenna
You didn't say what model you have.&nbsp\\; Is it a frame mounted antenna or a tour pak mounted one?
&nbsp\\;
BBB
Old 06-24-2008, 10:05 PM
psc's Avatar
psc
psc is offline
Steve-&nbsp\\; You might want to get an all rubber low profile one...believe they sell them at radio shack and a couple of other audio/car stores.&nbsp\\; My buddies have changed out both the Ultra and FLHX ones with all black rubber onesthey look better to me.&nbsp\\;
Old 06-24-2008, 10:09 PM
HawgriderPa's Avatar
HawgriderPa
HawgriderPa is offline
don't know about the 96, but on my 06 Ultra, I can take out the inner liner of the tourpak.. the cable coming from the radio has a knurled fitting that screws onto the antenna base that then is attached thru the tourpak.. the visible part of the antenna shaft then screws on there..&nbsp\\; and that part is replaceable
&nbsp\\;
&nbsp\\;
Old 06-24-2008, 11:47 PM
99igor's Avatar
99igor
99igor is offline
The antennas on a tour pack (At least the one on a classic) have a mount that is a threaded shaft. It has threads on the top, where the antenna mounts and a hole that the antenna cable mount is screwed into. It is replaceable but you will probably have to get more than one part.
&nbsp\\;
My antenna broke off like yours did and I found all the parts necessary in my parts book. You do have a parts book? Right?
Old 06-25-2008, 08:06 AM
steve marshall
thanks for all the replies.&nbsp\\; i will pick up a parts book this afternoon.
ERICKSON
2014-2023 Touring Models
05-29-2015 02:12 PM
lee123
07-24-2008 12:26 AM
bdp
07-21-2008 08:40 AM
twilliams
06-25-2008 10:35 AM
bbc2222
06-16-2008 06:02 AM
Quick Reply: broken antenna
